Four Galaxy Note 4 Accessories
jianrong
Hi guys,
Received my Ringke Fusion case yesterday. Quite disappointed in the quality. Reasons are:
1) Edge surrounding the soft case and buttons are a bit sharp/jagged, not smooth. Although it will not cut your fingers, but does not feel comfortable.
2) Position of dust protector flap for the USB port is out. The thin piece joining the flap to the casing is too long. As such, when I push the flap into the port, one end of the flap cannot fit nicely and is pushed out slightly by the too long connecting piece. It is possible that mine is a defective one and the rest will fit nicely. Dust protector flap for earpiece fits perfectly.
I like the look of the casing but not the quality.
Just my short review. Cheers!
My ultra hybrid clear i like it too. But the grip part is sticky.
Akai Ryu
blurtaurus
Need some pic to verify
Here are photos.
First photo shows the flap before being inserted into the USB port. You may notice that the position is already out (more to the left rather than the centre).
After inserting the flab, one side juts out due to the connecting piece being too long.
Akai Ryu
Here are photos.
If u bot it online, email with pic to justify. Most will resend. Just speaking from my UAG experience
If local retail, just bang table and throw coins :s22:
WhiteHunter
It's not. Iirc it's something called Dragontrail glass or something, hope someone can sic link as prove.
But Dragontrial glass is from Japan, I never doubt Japan technology haha. Anyway Gorilla Glass 3 and Dragontrail are both very strong glasses. If you're not going to any beaches, you don't need a cheapo screen protector to spoil your screen viewing experience.
Dropping is another matter, nothing can withstand a drop so this doesn't matter if you're putting sp or not.
I for myself are not going to put sp on my Note 4. But getting Neo Hybrid as the Note 4 edges are way too sharp. Neo hybrid tpu is the solution for me.
dunno where you heard or read that galaxy note 4 is dragontrail glass but i got official confirmation from samsung that the glass is indeed corning gorilla glass 3 with native damage resistance.
anyway most of the review sites all state galaxy note 4 is gorilla glass 3. dun think you will find any site which state its dragontrail. if you dun believe can ask samsung yourself to confirm.
zXioNGz
Because corning website didn't list Note 4 that's why some bros mentioned it last time it might be Dragontrial glass, since both are more or less the 2 manufacturer.
Don't so fed up la, lai give you candy be happy okay? :)
zXioNGz
By the way guys, anyone tried 2.5D tempered glass? Does it stick with or bubbles already?
Also I saw 0.26mm and 0.33mm tempered glass, does the thickness matters? Both same price lol
adix_82
Most important is to make sure ur phone can apply tempered glass.
WhiteHunter
your comments always try to act smart and give info as if its real but actual fact is anyhow smoke. those dunno how to check might take it as real fact. now i know why one user here so dulan with you recently.
jianrong
Still thinking whether buy otterbox def then remove glass protector since case come with sp.
But love the look of clear ultra hybrid. Lol.
bkling1
Not sure don't any how "Sian".
adix_82
Just go try the case and u will get answer. The otterbox demo are at Burlington square now.
