OK later I try to check.. TyDrivers should not be an issue.. if you didn't notice anything wrong - such as no audio / unable to toggle volume / brightness via FN key combo etc.
whoohoo.. windows 10 activate liao..Welcome to windows 10!
No worries - just let it update![]()
Also check if Windows is activated -
you can do so via here:
Hmm maybe Fujitsu's websiteHow to make those bright thing windows?(nt sure wats the correct name) to be darker? like too bright liao
The borders? - this I have to play play to figure out as well. Will update again- don't have a laptop with me right now
Got this error cant install my webcam
hmm does not seems to effect on the windows screen le..Try this!
I cant delete this folder..
dont have "Previous windows installation(s)"Windows --> search for "disk clean up"
Click on the highlighted text indicated in the image below
& look for err something along the lines of "Previous windows installation(s)" - should probably be all the way down!
Do note that Windows 10 has a feature that allows you to revert back to 7 (only for 30 days) and deleting windows.old will not allow you to do so anymore!![]()
Seems faster.. And smooth..Heh!
Dont mention it.
How's the performance compared to 7?
