Galaxy Note 3 4.4.2 Kit Kat update
reson90
After installing ND3 i wipe my phone for factory reset, current it last me with full day battery (estimate 15hr) with 4hr screen time and still left about 15%. None root.
djzilch
I really don't like this new update
My note 3 has never crashed on me even once
After this new update I closed my s view case and then when I opened the case the screen won't turn on, I found out the phone turned itself off when I closed the s view so I had to reboot
Never happened before the update!!
renfred89
Only 1 remote glitch can get u so hyped up.. there's greater things in life..
djzilch
remote glitch?
i had to remove battery and do a cold reboot (does not respond to power button or home button - for a few minutes i thought the set was dead)
never happened before too...
yea sure there are greater things in life but they are irrelevant - this thread is about the note 3 S/W updates isnt it?
kopitalk
I also encountered that once. I think the update made the Note deep sleep really well until it forgot to wake up? :p
deathst
Hi everyone, I quickly read through the thread and replies and I'm quite sorry to hear all the issues happening with the update on your devices. The updates are usually fine in testing but it seems to be not the case in public releases.
I would love to try help solve the issues you are facing without a factory reset but you would have to cooperate and provide me details that could help in finding out what is the Issue by going down a checklist.
Do reply with your answer to the check list here.
Checklist:
Do you have an External SD card
How much space is left in your INTERNAL and EXTERNAL SD card
Do you have applications moved to your External SD card
Have you tried clearing your Application cache?
Have you tried clearing Dalvik cache
-A Samsung Connections member-
Jurong640
Checklist:
There's External SD in my phone. Internal left 23GB, External left 10 GB.
No apps moved to SD. Cleared Application Cache.
How do i clear dalvik cache.
The very main problem facing is the SIM REMOVED and will restart the phone, very annoying. Feedbacked many times and not yet solved.
lampano
Anyone having the issue with FB/IG pics very slow loading after update?
