Galaxy Note 3 on VoLTE
Peabrain
Does it happen at one location? I have no problem sending sms ever since on clearvoice, and that my sms is sent in 1second..
It happens all the time. @ home , in office and my friends home. So is this some kind of software glitch?
renfred89
Could be sim card, could be phone. Its difficult to isolate the fault now.. perhaps you can call in to singtel and ask for assistance?
Peabrain
Hmm.. never had problem with sending sms with my note 3. So dun think is phone issue.
Will call sing tel and check. Thanxs
Spongy
Need help on setting my phone to Singtel's CSC as I bought it from Red white mobile. Anyone can provide guide please?
tjkb230
This is quite weird, I expect it to work on LTE network only. But the logo also appear for WCDMA (3G) and GPRS (2G).
Worse still, the logo also stay when I disable the feature on phone :vijayadmin:
kero89
yea that's normal. i tink its a bug on software level.
renfred89
Since Starhub has already rolled out its HD Voice+ (VoLTE), perhaps starhub users can also share your user experiences with us, and I would love to test if singtel VoLTE and starhub VoLTE can call each other and still experience the goodness while crossing carriers..
smokey
bump :s12:
renfred89
*only for singtel users*
Some of you might have realised you have network issues when your VoLTE is activated.
Common problems:
1) Cannot dial in dial out even though the network reception is healthy.
2) VoLTE arrows disappear in areas where 4G is present.
You can try the below steps and let us knownif it works. At least for now, it works well for me and i will monitor for a while.
Steps:
1) Navigate to settings > connections > More networks
2) select mobile network > access point names > then tap on IMS.
Once you select IMS, the option is highlighted and after a few seconds, it will automatically select Singtel (Postpaid) APN.
I tried this method and i got my arrows back after i lost it in areas with good 4G signal strength..
smokey
Thanks but it does not work for me. Still not getting the VoLTE arrows consistently with 4G, sometimes incoming calls not getting through with strong network signal.
Common problems:
Steps:
Spongy
I have the common problems with this VOLTE. I called singtel and they told me to wait patiently for the software update to appear and it will solve these issues. Apparently, the latest software is NE4 and I am on NF3.
renfred89
NF3 is to add support for starhub's HD Voice+.. therefore i think future updates will resolve such problems.
SK318C
I didn't know the arrow icons is for this VoLTE.
Will this thing uses more data?
My data usage is normally around 300 to 500MB per month, but now suddenly 1GB 2 weeks only (according to the Singtel App) since getting this VoLTE.
gapboy
Answer is on page 2.
ClearVoice | SingTel
Q. Which price plans are eligible for 4G ClearVoice?
A. 4G ClearVoice is available on all current data mobile plans: Super Lite, Lite, Value, Plus and Prestige mobile plans with 4G VAS on supported handsets are eligible for 4G ClearVoice from 31st May 2014. Calls made between two parties on supported handsets will experience crystal clear voice quality and super-fast call setup at less than 2s.
Q. What are the charges for 4G ClearVoice?
4G ClearVoice is currently free (no monthly subscription) for customers on eligible price plans with 4G VAS.
4G voice minutes are billed at the same rate as your current voice rates. Minutes of usage will be deducted from your price plan bundle and if any, additional talktime Add-Ons. Excess talktime will be charged at the rate of 16.05 cents per minute.
No local data will be deducted from your data allowance for the use of 4G ClearVoice.
fatangel
One of the tester reported this problem on his thread. He shared how to resolved it. Also a fix is coming .
Thou I think is scary not to be able to receive phone call. I will never know until someone tells me.
How do you realize you cannot receive phone call? Jus to share.
renfred89
There is a software update today: NG2 from the older NF3.
Perhaps users experiencing batt drain or VoLTE issues can try if it works, because the update is to improve stability.
Spongy
I have updated to the latest firmware on Saturday, same issues as I can't make calls. Have yet to test out on receiving calls. Really wished they would get the act together before rolling this out. At lest I know what is happening after reading this thread but most are unaware of the issues.
gapboy
i find recent days my note 3 battery went down fast too not sure what causes been monitoring my "running application" all seems normal.
Just disabled VOLTE on the call option to see if it is better...
