Galaxy Note 5 sleeping issue
Do you guys who owned a Galaxy Note 5, does it had the sleeping issue
  • Yes, I had the sleeping issue
    Votes: 140 77.3%
  • No, I do not encounter at all
    Votes: 41 22.7%
  • Total voters
    181
peterg
try use default wallpaper and theme.
i have no more sleeping issue after changed the setting above.
jnashville
I'm using 32gb and it has sleeping issue.
icic. all of my 32gb got no sleeping issues..telco sets. maybe i am just lucky~
tested on 3 different sets.
Even without disabling quick launch or any apps. using stock.
WhiteHunter
b4 i disable quick launch for camera, i using default theme n wallpaper also got sleeping issue very frequently.
Lamwm
I observed that if my note 5 went to sleep in stationary position, it never happens the sleeping beauty problem. I always can wake it up. The sleep beauty problem only happened when the phone was in my pocket or hand when it went to sleep mode.
muddle
If that's the case, should leave your note 5 at home in the box. Sure no sleeping beauty.
lxb_70
Seems like this issue can't be solved at the moment... some disabled something, ok for them but not for others... i still strongly think that is sammy who write the fw into deeeeeep sleep in order no wakelock issue, to drain batt.. correct?
Sent from the dark side of the moon using GAGT
selferng
Don't try those myth method. I format my phone and use audax rom... Fast and no more sleeping beauty :). But since h need to root , it will trip your knox and no more warranty.
So u have 2 choice.
1. Root and flash a new rom
2. Wait for sammy sister for an update
wesdork
So u have 2 choice.
Hello, may I know if flashing a new custom rom retains the S Pen functionality such such as screen off memo or smart selection... Etc? Or do I have to install a separate package for that?
Kopi_Lui
I kena a few lags per day.. like whatsapp or message app will lag.. but spontaneously resolves by its own.. hahas
i just kena it on my Message app (SMS). I launched it intending to send an sms and it became unreponsive (no reaction). after awhile it becomes reponsive again. this is quite concerning
selferng
Hello I m using s6 edge plus. So I can't advise those. But u can go to xda forum for note 5 and check it out. Bear in mind, it will void your warranty
