Galaxy Note 5 sleeping issue
Do you guys who owned a Galaxy Note 5, does it had the sleeping issue
  • Yes, I had the sleeping issue
    Votes: 140 77.3%
  • No, I do not encounter at all
    Votes: 41 22.7%
  • Total voters
    181
lxb_70
Guys, some of you had the sleeping issue on the Samsung Galaxy Note 5, some of you do not.
Let's see how many of you had the issue. Post here, for info.
porcu
Yup,sometimes need several attempts to wake up the phone again.
human_shieldz
Wah 10 people has it. Someone should bring this into Samsung's attention. Maybe then they'll remove S-voice when their sales start dropping like grapes
tkl23786
16:4 now...
Pretty random occurrence
Sometimes never had it for the whole day, sometimes a few times a day...
MenToy
I'm the 5th. I did not face any issue so far since 1st day of Comex. (Cross fingers)
hanciyap
Note sure only certain model affected. Anyway mine is black 64gb. Have the sleeping issue since day 1, also have few time phone auto restart. Anyway, i cant take it anymore and plan to send it back to samsung sc at plaza sing next week.....
Alexz_Hong
Think Gary was the one of the first few to post about this issue (http://forums.hardwarezone.com.sg/95891527-post671.html).
http://forums.hardwarezone.com.sg/95893606-post688.html
Mine was from launch day till now. I will encounter that issue i think at least once a day everyday for the first week. Then i did a factory reset and wipe cache partition using the stock recovery, which seems to help. Nowadays, I can go days without seeing it, but confirm still around. In fact, just had it happen this evening. Tried to turn on the phone, but took like 3-5 secs for the phone to wake up. :s22:
hanciyap
I've checked the software version at the shops (samsung, singtel or m1). The model number listed as SM-N920X which is different than ours SM-N920I even software version is not the latest one. Im wondering the display model is different than what they sell to customer? I've been testing/playing note 5 since the launch day almost everyday at the shops and finally bought it, i didnt encounter any issue at all while testing with the display set.... im really sad now with my note, this sleeping issue is really bad. :(
Alexz_Hong
i'm wondering if it could be some third party apps that doesn't play nice with the chipset? But it would be damn near impossible to pinpoint. :/
hanciyap
Dont think so..... i did everything i can already, clear cache partition, factory reset few times, disable Svoice etc. Samsung push out 2 update recently and each time i also did factory reset after the update but no use. Even i also tried just install whatapps and facebook 2 apps only and monitor it but still getting the sleeping issue. I never have such bad experience before, its so unstable.... dont know what to do now. :(
MenToy
Which model is your? I mean (color & storage)
My is 64gb Gold Matilic. I use it directly without factory reset. So far so good.
Based on my experiences since my note 3, i realized a lot of problems caused by some apps i installed, especially battery run out fast due to some apps running un background.
Now I'm very picky about apps i use and observe which are running in background. Comparing Note 3, Note 5 is a great upgrade. To me is worth it.
K.laus
Try disabling wallpaper motion effect
Sent from Samsung SM-N920I using GAGT
