Galaxy Note Accessories
Jeremy1
Today used the default ear piece for 1hr+ of music listening. Ears feel a bit pain and uncomfortable.
Read somewhere that Klipsch S4A doesn't works well with SGN. Anyone can recommend a good one with mic and remote ctrl that is compatible with SGN? Budget between $80-$120+/-
Thanks
Can bring your note and go down to Stereo and try it out.............;)
kiong27
Not really the good way to check the fake one from the original as what my collick told me. Yours is quite obvious but the one my collick got from GM is totally identical when he let me compare to the original. But its only last u a couple of hours when fully charged.
The only way to check is to compare the weigh. Original one will feel heavier or try to scan the QR code. It should be the same as the original one but usually the fake one cannot be scanned at all.
Maybe the best is go buy from Samsung shop?
Akai Ryu
Pattern Breaker
Jhyun
Not sure how true this is, but the weight difference is obviously there however, and indeed I'm unable to scan the QR code on the sammy lookalike battery. Looks like it may be a valid method to check for now.
neubie
80 buxx might as well buy external USB battery charger with spare change to charge many devices.
algerr
Thanks
well.. you can try out creative EP-630i around $40? good bass - or go stereo electronics branches to try out other sets - Stereo your one stop headphones and earphones store in Singapore
How much is original batt?
Asked from the shop 2mths ago, it's definitely not cheap, $98 (retail box)..
If you want cheaper alternatives, buy a portable charger or get spare batteries..
got it from e-bay before, fast shipping from South Korea - less than 10 days arrived in SG.. - spare battery(oem) + charging dock (charge quite fast, around 3hrs to fully charge a battery):
Original Samsung Galaxy Note N7000 2500mAH Battery + Battery Charger Cradle | eBay
Jeremy1
This is what I think :
Since new model coming out every year so I will not spend money to buy too expensive accessories unless it can also be used on newer model.........................;)
So no intention to buy extra battery since new model might not used the same one. Casing wise, just a cheap one will do. No need to buy more than $100 buck branded one unless you intend to use this phone for a long time.......................:D
Vulpix
Moderator
Moderator
Sian, the coating on my screen protector coming off liao. Never use any potions or liquids on it so far somemore. :(
Vulpix
Moderator
Moderator
Wow, okay I managed to find a company able to do small volume cuts for screen protectors with their machines. Would anyone be interested if I can cut down the 3M Estoc+ for the iPad 2 and sharing the cost?
Jhyun
Count me in :D
theory_87
2 for me :yawn:
