Galaxy Note Accessories
Akai Ryu
tried ajays one+ with remote app installed, cant seem to get the single button to perform other function except for volume up & down.....wonder if its demo earphone got problem.....:(
tried with stock music player....upon further testing....activated my other MP3 player.....:o
saggydog
mobicrab
Love this but the price is a killer not too sure if is a real 18K gold plated mobicrab
Akai Ryu
yup all these korean bumper going at the 90 range as well but i recall seeing one mobicrab going at 60+ at gmsg....now LF glider going at same price as SZLF :s13:
anyway for those who are getting or waiting for your sweet armor original, dont use the philip screw driver provided, it cannot fully tighten the screw and i realised i lost one screw today, fortunately it came with spares and can be fully tighten with proper tool
if there's anything to improve for sweet armor, the paint should be powder coated
edited: just saw ur link to the 60+ mobicrab LOL
saggydog
Yap not too sure if is a error post the others post from the same seller is 90+
Akai Ryu
hey vic which one u using? the one+? If so got any issue using the remote app?
i should probably ask this at earphone subforum but i badly need feedback about this.....was the demo one+ i tested with remote app a dud? :( anyone???
philips android earphone worth waiting?????????????
napestarr
Mine's the L-jack already.... failed on A-jays 4, A-jays One.
For me personally, I'll never buy another A-jay series anymore.
Just a simple search would give you tons of complains about the A-Jays, L jack or non.
I guess its the experience that counts. So far I am ok with the series. aJays three has been great so far after the RMA to the L shaped jack. *touch wood*
:s13:
plus I am ok with the sound quality for the price.
Akai Ryu
Akai Ryu
ok thanks but actually i like this design more though. :D
Does look appealing in some sense especially certain colors which are not available for other "brands". But if you read abt the feedback given by some here, esp the part whereby the sliding frame will drop off upon impact, it says alot about the design of this bumper. Im sure most will prefer a bumper that looks good but most importantly function well.
wah piang..
so many diff kinda bumpers..
confusing sia.
which should i get? can recommend?
Ok i may be wrong but based on the current available bumpers for GN, actually only two broad differences if we dont compare price.
MIC, Sliding frame mount aka Bummers : SZLF, LF G.Lider (korean branded), "Fake" Sweet Armor Note and LT
I only tried Glider once, i took it off immediately after mounting and taking pictures. I think that says something about the design factor. Basically when sliding the frame in, u get a sense that it will scratch the screen and even though it had cushion lining, i wasnt confident that it will not scratch the bezel, which did occur to some SZLF users. The audio jack cut out also had alotta issue, many earphone jack cant fit including stock. Some had to contemplate whether to file the hole bigger or buy extension cord etc. SZLF and Glider basically the same. Sweet Armor Note, well u can find the post of the horrid review of the flying frame. LT uses the SG2 bumper design which doesnt allow back cover access which may not be a problem for those who dont change batt OTG.
Korean branded (made(?)/ Screw mounted : Don Star, Mobicrab and Sweet Armor G.Note
I can only say that the Sweet Armor G.Note is a well design bumper that may not appeal to some aesthetically, but most importantly function well. The main diff is that it has the protruding button caps for Power button, and Volume rocker. Some may prefer just a cut out for these button, but from using Glider, i find it a hassle as its harder to activate the buttons. In case anyone's wondering, the protruding button cap does not wake the phone accidentally when in pocket, how u wake the phone when u take out your phone is another story.
Interestingly, although Sweet Armor G.Note add some width to your device, it actually made it easier for single hand operation (somehow that doesnt sound right :o) with the groove at the back of the phone. My initial impression of not seeing the need to use Bunker Ring stays. Just read the XDA review of this bumper, it helped me alot before i click the "pay" button. ;)
As for Don Star and Mobicrab, they're relatively new and cant find any review thus far but "no button cap" does not work for me, advantage of these two vs Sweet Armor G.Note could be they use less screw, Alan key type for one of them iirc whereas Sweet Armor uses philip.
