Galaxy Note Accessories
user.name
Does look appealing in some sense especially certain colors which are not available for other "brands". But if you read abt the feedback given by some here, esp the part whereby the sliding frame will drop off upon impact, it says alot about the design of this bumper. Im sure most will prefer a bumper that looks good but most importantly function well.
Ok i may be wrong but based on the current available bumpers for GN, actually only two broad differences if we dont compare price.
MIC, Sliding frame mount aka Bummers : SZLF, LF G.Lider (korean branded), "Fake" Sweet Armor Note and LT
I only tried Glider once, i took it off immediately after mounting and taking pictures. I think that says something about the design factor. Basically when sliding the frame in, u get a sense that it will scratch the screen and even though it had cushion lining, i wasnt confident that it will not scratch the bezel, which did occur to some SZLF users. The audio jack cut out also had alotta issue, many earphone jack cant fit including stock. Some had to contemplate whether to file the hole bigger or buy extension cord etc. SZLF and Glider basically the same. Sweet Armor Note, well u can find the post of the horrid review of the flying frame. LT uses the SG2 bumper design which doesnt allow back cover access which may not be a problem for those who dont change batt OTG.
Korean branded (made(?)/ Screw mounted : Don Star, Mobicrab and Sweet Armor G.Note
I can only say that the Sweet Armor G.Note is a well design bumper that may not appeal to some aesthetically, but most importantly function well. The main diff is that it has the protruding button caps for Power button, and Volume rocker. Some may prefer just a cut out for these button, but from using Glider, i find it a hassle as its harder to activate the buttons. In case anyone's wondering, the protruding button cap does not wake the phone accidentally when in pocket, how u wake the phone when u take out your phone is another story.
Interestingly, although Sweet Armor G.Note add some width to your device, it actually made it easier for single hand operation (somehow that doesnt sound right :o) with the groove at the back of the phone. My initial impression of not seeing the need to use Bunker Ring stays. Just read the XDA review of this bumper, it helped me alot before i click the "pay" button. ;)
As for Don Star and Mobicrab, they're relatively new and cant find any review thus far but "no button cap" does not work for me, advantage of these two vs Sweet Armor could be they use less screw, Alan key type whereas Sweet Armor uses philip.
wow thats a long post :s13:
thanks the information. so in ur opinion, sweet armor Gnote is the best?
philip screw and alan key type got diff? :s11:
lastly, can share where u bought ur sweet armor gnote??
thanks :D
Akai Ryu
thanks :D
I did not use all the bumpers mentioned, so cannot be a definite best, but if based on the two broad categories, yes in terms of the thought and build of the design. But just as any other coloured metallic bumpers, i wished they were powder coated :o
The philip screw is for Sweet Armor G.Note , which is mounted from the back whereby the phone sit in the bumper secured by a front frame which needs to be screwed (somehowthat doesnt sound right again :o)
As for one of them (mobicrab or Don Star) which uses alan key, if u look at the pics, they're side mounted, similar to some ip4 bumpers. They also attempt to market its difference in terms of the material used, duraluminium iirc
http://www.sweet-armor.com/6-sweet-armor-gnote
edited: There's also the TPU bumper and Anymode PC bumper which is not mentioned due to difference in material, but basically these two type does not allow back cover access
user.name
me is very noob haha cos i switching from ip4.
non powder coat does it mean its like deff cleave for ip4? easily scratched?
btw hard to install ma?
Akai Ryu
powder coat ish u scratch liao less likely to see the "metal colour", most are liquid paint coated, iirc some stated theirs as anodized aluminium, in this case the colour is dyed if im not wrong, meaning scratch liao wont see innate colour "silver"
very easy to install, just take note of ensuring that the screws are tight and secure, as mentioned in earlier post, i lost one screw out of the four due to initial installation using their philip driver and probably also due to my excitement of hurried installation just to see how the bumper look and feel in my hand :o
edited: since talking about colour, Sweet Armor Gnote's black is matte, while SZLF/Glider's black is more glossy
user.name
ohhh.. ook thanks.
gotta think whether to get red or gold now then..
no local shops sell any of these right? saw a few ppl selling on marketplace. those fakes? :s11:
Akai Ryu
ohhh.. ook thanks.
i mostly hunt online but fr what ive seen and read, SZLF and "fake" Sweet Armor Note "not Sweet Amor G.Note is available in some retail store.
ebay flooded with SZLF type bumper
Akai Ryu
ohhh so its a something like a replica la
okie will try from the site u recommend then
hope it doesnt disappoint me cos its damn exp :s13:
thanks bro!
it was more expensive when first launch, it was only after some XDA forummers email complaint/feedback/haggle then they let it go on "sale" :s13:
edited: not a replica, its actually the first available bumper for note, the iron man got some of the early adopters into a frenzy initially :o
damienism
actually i don't mind using bumper, if it offers good protection. since my previous sweet-armour feel apart incident, my nice alum-batt covers have been in cold storage. what a waste. still looking for a bumper to use with the nice batt covers.
now still waiting for my pleomax case and bunker ring to arrive. my Zenus Prestige top flip case aldy shows signs of leather-wear at corners and the elastic strap which i slip my hand across for more stable hold is koyak.
on the other hand, lately i have taken fancy and itching to buy the Verus Triplex hard case, especially the germany color combi (black,red,yellow). cheapest i found in gmarket.sg is around 30+sgd.
KYLee
As for Don Star and Mobicrab, they're relatively new and cant find any review thus far but "no button cap" does not work for me, advantage of these two vs Sweet Armor G.Note could be they use less screw, Alan key type for one of them iirc whereas Sweet Armor uses philip.
Thanks for the reply! i guess i'll just go with the plastic two-tone bumper i bought from ebay! :D
KYLee
might as well use TPU cover :D
cause i bought carbon fiber back plate to use with my white note.. but wanted to protect the bezel or the phone if i happen to drop it.. currently using mercury TPU and find it abit thick leh.. :D
Akai Ryu
Innovation Silicone Protective Shell for Samsung GT-N7000 Galaxy Note : neTimes.com, Smartphones Accessories
