Galaxy Note Accessories
pinky867
I have no hard evidence to back up but phone does seem to feel less hot when use intensively, like gaming, batt life seem to stabilize but they may be to some tweak I did. I monitoring phone temp with batt monitor widget and Android system info app, but have not really noticed a trend, only that the max my phone heat up is 39. maybe coz it's measuring system temp and not batt temp (?)
Oh ic, no need hard evidence just hand test will do. :)
Care to share the tweak that you did?
Did you get yours from Gmarket? I've tried searching in there but got 0 result. Any idea if Singapore have them?
darknez
No reason for me to remove elago, damn impressive with the oleo quality, if I use my estoc and kena same result then it's suay or qc problem. One of my colleagues' estoc faced similar scratch rainbow, fortunately at bottom corner and didn't have the fingerprint magnet white powdery residue issue which I experience.
This could be the reason why they are discontinuing the Estoc+. The QC is getting from bad to worse.
davi502
Considering that we have just ordered a bunch of Estoc +, that doesn't sound encouraging :(.
xolatw
any idea where to get good and cheap usb cable? the one that comes with it is so short i dunno how to use it
Akai Ryu
K can still feel heat, hopefully dissipated effectively. Bought fr gmkr
Akai Ryu
K Vulpix's 10 order Mo, I got a lemon while another had slight scratch problem, my order of 6 had 1 with qc problem, have not open mine. So depend on how many u guys ordered, if there is problem ~ Touchwood~ then can tell the extend of their qc. I still believe it's a Gd sp based on my first day of use, dunno why after that went downhill. Since no complaint from the other users, still can be trusted. I scratch test it before removing for elago and it scratch very easily. Will test estoc again when u guys receive ur latest order to cross reference experience again.
Akai Ryu
theory_87
There is... just im lazy to complain... the sgs2 estoc+ imo is still the best
N3wXTyp3
Out of topic, I ordered 1 for my mum's S2... will see how it goes.
My SP still quite good. but the white residue is there. I just clean it off normally!
darknez
Don't worry. After so many purchases, only one or two cases. And if I'm not mistaken yours is a new batch.
