GALAXY NOTE II ACCESSORIES
Sinkie
just a question.
i have not used a microSD card for my note 2 yet as i think the space is sufficient for my current usage.
But if i were to add in a SD card, would it result in the phone lagging?
in my previous note 1, it does result in the phone lagging in performance.
no lag at all or maybe it is not noticeable
buy class 10 sd card one, more shoik.
yellow_pen
hmmm ok cos i worry it will be the same case as my note 1 if i put in the SD card :s13:
what's the difference between all these class of sd cards?
Sinkie
in term of the read/write speed nia ba.. i saw people saying class 4 one also ok
yellow_pen
you got buy any protection casing for your note2?
Got. Transparent casing for the back, brought from gmarket de, dunno whst series or brand, only $6:s13:
Then got a privacy screen protector from adix82 for $22 if I remember correctly.
What about u?
Akai Ryu
Sinkie
What about u?
i hoot a matt screen protector for 5rm but havent buy any cover.
dont know should get the flip cover original one or not.. i like the casing that can replace the back cover but not sure will i like the flip cover or not
derazor
akairyu bro, some questions
1) all casing need to remove the note 2 cover?
2) i need something that looks executive but it must be slim . can recommend?
zercab
hey guys. need to ask sth. i installed some cheapo screen protector and got some rainbowing effect.
now i wanna remove and change it, will the "glue" from this screen protector affect? or i shld just suck thumb and use this sp?
Akai Ryu
1) only need to remove back cover if ur going for those flip cover type. Else not necessary to remove back cover for TPU, wallet, snap on case especially when the NFC chip is on the cover
2) quite alot are using the $68 original samsung flip cover....its offers some protection for the screen but have to sacrifice for lack of protection for bezel and back of phone. Go with snap on or TPU for thin profile, really is about user preference here.
