GALAXY NOTE II ACCESSORIES
Downloader
I read the bunker ring not for silicone case.
I bought a cheap soft translucent white case for temp use from a back/side lane shop in sls run by prc. Actually love it very much as it retains the look of my white note 2.
Is this the so called tpu case? Will it work with the bunker ring.
Actually deciding between the bunker ring or flygrip.
Are they not available locally? My bro is in LA now. Wondering if it will be possible to get it from retail there and if cheaper.
Sinkie
Bought the flip cover samsung original one at $55 Liao..
Singtel selling it at $69
kennyboy
I love the bunker ring.....I will change the casing if it won't work with the ring. :D
But it's a crapshoot which case will work. Some smooth flat surfaces won't stick, but some that looks like it won't, with powdery surface works. No way to tell for sure until u stick it on and use it.
But for me the usage of the ring wins over any aesthetic concerns, so it's ring over case. :D
mac34mac
Yup, using the Sandisk 64gb Class 10 as well. No issues so far and loving the huge storage capacity....
I bought mine from Fuwell SLS at $77
No problem at all, using that now...
Are you guys using FAT32 or exFAT format? I read from other forums there are some issues with exFAT in GS3, just wondering if Note2 works fine with it.
Akai Ryu
