GALAXY NOTE II ACCESSORIES
zechraffie
My kinda case.. All in one, grab and run!!
Where to get this bro Akai??
selenger
Hi, anyone using the Mercury casing?
Is it normal not to be able to charge w/o removing the casing?
Like the casing though! Bough at Adix, should have gotten the screen protector from there too.
tikokia
why must remove to charge??
satch
Mercury case is quite thick. And wraps around all edges. And also cut very precise. Thus the micro usb head connection point on the charger may not be deep enough to extend fully into the note 2 charging port when inserted
frizee
Guys, any recommendations on Wraps? Need to protect the bezel and the Back-Side. :)
satch
yup, can't fully insert the micro usb.
any suggestions for alternative similar casing?
thank you!
You can try a usb cable with a longer extending tip?
Btw better check if ur mercury case is genuine... mercury has been around some time and their cuttings are normally good fit . didn't have issues with my past mercury cases.
