Good Power Banks?
hawlam
Yeap. Mine is the 10k. I was actually expecting more from it.
Or do I have to *break in* the battery? That was my first use with it.
maybe try season it little bit
by right powerbank no need to season it too
or its might be a lemon set
jaymessofly
If lemon set, anybody knows what Xiaomi's exchange policy is like?
I bought it from Xiaomi's website directly.
EldonChew
Thanks guru. Was just expecting more, haha. But if this is the acceptable rate then I'm fine with it.
If you go Qoo10 and search for power banks hor, there's those unbranded 12,000 or 20,000 or even more etc
I don't even think their conversion rate is more than 50% even with best case scenario
Xiaomi 16,000 one min. conversion rate is 62.5%(usually would be more lah but worse case scenario is 62.5%)
http://www.mi.com/sg/mipowerbank16000/
Also, here's their warranty claim and stuff
fade_white
For your Xiaomis, are they holding up charge well?
Just bought mine and only managed to get only one full charge for my iPhone 6 and iPad Mini 2 out of it.
I charge my iphone 6 twice and ipad mini 2 once (from ~20% to full) the LED indicator says that 2/4 of the bank is left.
jaymessofly
Wah, mine from 0-100 once nia for both then the bank die liao. You using which capacity? Mine is the 10400 one.
fade_white
10400 too here.. Just got it a week ago. Maybe the second led is almost gone liao, but I remember still got power left after I charged my iPad..
are you using the original iphone cable? don't know if that has any impact...
hawlam
sounds like a tpyical samsung cell lemon set
their xiaomi phone battery aslo got issue actualy from one of my friend use for less than 3mths then issue with gps and battery
then he go RMA it
jaymessofly
I'm using my own Verbatim 30cm cable to charge when using on the go. Sometimes use Apple when I carry a bag, then can put the power bank in a bag.
then he go RMA it
Thanks bro, will call up the service centre and see what they say first.
hawlam
i used your verbatim and apple original on my sanyo/panasonic powerbank from japan
no issue onmine side
is not the cable issue or yor phone
is the lemon powerbank xiaooomi :s13::s13::s13:
should have go for more relilable powerbank like sanyo/panasonic or even sony
hawlam
another way to polong any portable device battery
dont use supe high power outpuet charger
it suck the life out of a battery lifespan
and cut short it
for iphone i use max 1.5a output same for my powerbank too
if u dont worry of replacement then go for 2.1 or higher too
siron
and cut short it
Didn't know that .....
I like use 2.1 cuz its a lot faster eh. So far no issue eh
audioenslave
Any recommendation for slim powerbank perhaps like 6 plus thinness and above 10k battery juice?
Melvyn_
Use Power Banks that have the technology of automatically discharging the correct output to your Device. Like Anker's Power IQ Technology or Xiaomi's Powerbanks.
