[GPGT]2025 PSLE toughest math question
Dracky
It is just a simple test of logical reasoning. No need to over-complicate the solution using algebra. This is a way to filter those student who can think from those who just did many TYS.
Kiwi8
Deluxe Member
I think this one is not difficult, as long as one correctly identifies that the 18 cm also applies to the other side where the white triangle is, I had marked this out.
After that the side of the triangle, AB, is simply 41 - 18 + 3 = 26 cm.
Then the side of the other triangle is simply 26 - 18 = 8 cm.
Perimeter of the shaded parts = 26 + 18 + 18 + 8 (for the left portion) + 26 + (26-3) + (26-3) + 3 (for the right portion) = 145 cm.
3G SAINT
When student can solved such question, what kinda job can they do in future?
Yesterday took bus and heard mum talk to own kid...;)
You must learn from cousin,how they get gd result,mum not look down on you...mum want you try your best:D
You must try to figure out why many pple went interview why other pple success,why some are fail...
I look at kid, he look stress think like secondary school boy:)
x1243x
I mean I can do this but with algebra… but this for psle?
no need algebra..I did with algebra but just thought of a way that doesn't require it. need to visualize them as 1 imperfect triangle and 2 triangles with the same imperfection
Yowe55 mini
Those who cannot solve can only do grab food or drive for grab
Dear mcylo,
I can solve it but I am still unemployed.
Confidence for the future. More good years ahead... Let us take Singapore forward together.
Thank you.
