(GPGT)Espresso machine hoot
purpleberry
Which TP Link did you shortlist? What’s the reason for shortlisting this brand?
Just the basic model, HS100. Overall reviews are good and app seems stable. Best one to date is Belkin's wemo but much more expensive. I dont need one that measures electricity and so on, just basic functions are fine.
patryn33
What is your max current requirement? This does 13Amp. I come across ppl in the states wanting plug to support 20A and not the norm 15A. So if you system demands a lot of current it may not be for you.
https://www.tp-link.com/sg/products/details/cat-5258_HS100.html
tremor
I bought the dlink smart plug but have not used yet. No budget to upgrade from my dedica ec680. But I bought a non pressurized basket for it.
blues7
I’m new to pour over coffee or is it known as drip coffee?
Looking to get the drip cups and gooseneck kettle
Any shop in SG selling?
Thanks in advance
patryn33
Thanks in advance
Goose neck kettle? That’s pour over but there are a few types. Read below and tell us
https://www.primermagazine.com/2018/learn/pour-over-coffee
Cups? Or server?
http://www.kalita.us.com/products/server/2988
https://www.hario.jp/pickup_vuw_m.html
blues7
Thank you for the URLs
I’m keen to try Chemex method
Any shops in SG sell Chemex materials/accessories?
I have some double wall cups for my Nespresso but again keen to try new types
Cups? Or server?
patryn33
Chemex... try
https://papapalheta.com/products/classic-coffee-maker
https://www.aspreso.com/accessories
Regarding double wall glass sorry can’t help
I don’t need the heat retention feature even today my low is 4C
My coffee never gets to the pt it’s room temp for me to drink
My spouse have the issue but such cup wouldn’t be able to retain heat past 2hrs any way.
U may want to check this thread out
https://www.home-barista.com/advice/espresso-demitasses-ceramic-or-double-walled-t25237.html
blues7
Thanks again
Double wall glass more for aesthetics
Anybody bought Chemax online and have it delivered from outside SG?
Chemex... try
patryn33
Thanks again
Aesthetics... beauty lies in the eye of the beholder. No one here can really help, u have to just look around
I will have to consider getting those paper filter with it. There are the bleach ones and unbleach ones. Amazon not avail?
