White surfaces reflect more light than dark onesWe selected package B for the toilet tiles' colour: (Image taken from Google search);
IMO, the toilet looks a lot brighter due to the white wall tiles.
Somemore this one like glossy finish also
Bishan BLK 20x to 2xx either done or ongoing currently. (Those closer to Bishan Park blocks)Bishan
Quite a few blocks here haven't started. In the high 200sBishan BLK 20x to 2xx either done or ongoing currently. (Those closer to Bishan Park blocks)
Same. Mine jus completedBishan
How long did it take? And did you stay or move somewhere elseSame. Mine jus completed
Not cut off everydayHow do you all boil water at home? I see that one cannot turn on gas because it's being sealed off from dust. Electricity also kena cut off.
Only the day when they need to do the wiring. Few hours only. So use an electric kettle
For mine, they did not askfor DB box replacement/upgrade is it optional?
did the contractor ask if you would like to replace or you told them no need?
Water leh? They need to replace the water pipes so need to cut off the water
jialat my DB box insai my kitchen cabinet
open door can access, hope they won't hack my cabinet![]()
All the best, bro! Please update us. Moi HIP coming soon too. I am worried coz I have cat and dog and some other small animals....no idea what to do.....Jialat leh my HIP starting on coming Monday. Jin Sian
You need to move your pets to some temp location.All the best, bro! Please update us. Moi HIP coming soon too. I am worried coz I have cat and dog and some other small animals....no idea what to do.....![]()
Thanks for the advice.You need to move your pets to some temp location.
The human movement, dust and noise will affect the mental state of your pets.
I dunno what other pets you have beside your cats and dogs.Thanks for the advice.
while I don't know where to move them, I will look into it. Was planning to lock them in the study room and bed room. Because shifting them to an unfamiliar place might frighten them.
The huge knocking noise and amount of dust generated on the 1st few days will not be good for them.
Unfortunately, the knocking can carry on with your adjacent units the next few days.
Maybe you can get some of your friends to be their nanny.
Or move to your relative's house if you are planning to stay with them for 2 weeks.
