[GPGT] Moi house going thru HIP, life without a toilet ish hard! :(
Medicated Oil
Thank you, I appreciate your recommendation. Will start to plan this November.
I dunno what is the layout of your hdb unit.
So, the knocking will commence from the 1st unit at your floor level.
If your unit is situated in-between, the knocking will start a few days before your start date.
Prepare for your pets to be moved for 1 month.
You can check with the HIP office on the start date and finish date for your whole floor to help you in your planning.
kw442
Water leh? They need to replace the water pipes so need to cut off the water
For our house, the main water pipe passes through the master bedroom, toilet, kitchen toilet, and then kitchen.
On the first day, they installed the plastic/PVC hose so we still have water in the kitchen.
RinoaX
Mine just finished.
What a nightmare.
For those that have to undergo it, best book/rent somewhere to stay.
kw442
Make sure you are around on the 7th, 8th, 9th and 10th day.
7th to at least visually inspect the wall tiles;
8th to at least visually inspect the floor tiles;
9th to tell them where to install all the barang barang in the toilets;
Try to use all the things in the toilets such as taps, shower and WC.
Check for water leakage (under the basin, basin,WC etc), cement/dirty spots, white cement not done properly, got hole in the floor to lock the metal gate, painting is done properly etc.
Medicated Oil
Need some advice here.
Should I install new water heaters in both toilets before or after the HIP?
Thanks in advance.
Do it during or after HIP.
I dunno what type of water heater you have.
My electric water heater is installed by the HIP guys.
Another tip:
Buy a small basket (with holes at the bottom to go through) to carry your toiletries for you to bring down to the toilets downstairs
You can also tie a string and/or get a hook
So you can hook them inside the toilet
Don't worry about the toilet. I've seen some of them in various HIP projects. They're generally clean. I'm guessing they have people who clean the toilets throughout the day
Thanks in advance.
Get the workers to install for you. It's free.
Get them to install everything for you!
Just go out to buy all the stuff you need.
Towel pole or rack. Hooks to hang pants.
Soap holder.
A nicer sink if u dowan their sink.
Mixing taps for ur sink and shower
Toilet paper holder
Rack for shampoo
Mirror
Cabinet mirror
crimsontactics
Very good advice Bro kw442! :)
