Can Or Not
- Jul 15, 2024
If you are lucky the pen can use…Lost count on how many times need to use lighter to “burn” the pen
Unlucky the tip drops and ink splashes onto uniform. Go back home kena 10x jialat from mummy.If you are lucky the pen can use…
Don't use this cos the hexagon surface hard to grip and result in callus.Your pen not red leaf brand one ah?
Young chewren time use this can rub until the paper torn.You will be a PG or MG if you had used this before the birth of liquid paper
Wonder who never tear a hole while using this.Young chewren time use this can rub until the paper torn.![]()
For all my life i didn’t know this until 14th July 2025, 0800hrs.The truth about the blue eraser
Usage is banned during psle and o level, a level. Don't know what they thinkingThese two bottles have to come in a pair
搞不好 you heat until the ball can shoot out followed by a burst of ink.Unlucky the tip drops and ink splashes onto uniform. Go back home kena 10x jialat from mummy.
paper eraserYou will be a PG or MG if you had used this before the birth of liquid paper
You don’t use this to erase … you use this to strip a layer of the paper off to get rid of the mistake, but 搞不好 you make a hole in your paper.
And tore a hole in the paper...You will be a PG or MG if you had used this before the birth of liquid paper
