Graphic Card Recommendation
ZrE0_Cha0s
OK, saw that zotac gtx 1030 2gb selling at $124 and gigabyte gt 1030 2gb is selling at $134 at Tradepac. Are this 2 gpu the ones that u are talking about? Is there any difference between them?
the chip they use is the same, just different in design and cooling.
zaizai66
I looking for something to tahan till my whole pc died as its already 5 years old already, not sure how much longer can it last. After that then will replace with a new rig
I suggest you go buy a second hand GTX 560Ti for $30 in the marketplace or carousell, that should last you another year. GTX 560Ti can hit over 100fps at 1080p resolution. Then upgrade to a GTX 10xx after a year since GTX 11xx series is just around the corner. By then GTX 10xx will be much more affordable.
Never buy a brand new GTX 10xx at the bloated price right now..
MagixuserII
then a second hand 560 Ti is perfect for your need. It will tahan for a few more years. 560Ti is still powerful at 1080p resolution.
560Ti > 1030
zaizai66
OK, thank alot, really thanks to everyone who gave advice, greatly appreciate it as I totally don't know anything about computer stuffs. Really wonder how you guys pick up on all these, where can I go and learn? Or anywhere online that I can read up and learn more on all these stuffs?
yup.
but its up to what u can find as well.
MagixuserII
Wow! Thank you so much!
BTW, what power supply are you using? 560Ti uses 2 x6 pin power connectors. Please refer to the image below.
Phen8210
i suggest u get second hand cards for your budget.. u can probably get smth like gtx 770/960 if anyone is selling at a fair price.
zaizai66
Hmm... Only now then I know that dvi provides better quality viewing than vga... Pls pardon my ignorance on all these stuffs...
