Same problem. I emailed them and they haven reply yet. Going down on monday before i enlist to take. If cant collect then gg lor. Go inside kena
from rp and they havent really been helpful so far on that part, called them instead of emailing though so not sure if it makes a difference? will be going down on monday to see if its possible to get it otherwise probably trying to get one of the transcripts printed out first.....
Hi, if you are looking for a non camera Nokia, may I suggest the Nokia N130, it is a but of an older phone, but it has a micro SD card slot that you can put music on. Plus, it has a headphone jack. http://www.gsmarena.com/nokia_130-6570.php
And yes, you can remove the camera, or just ask the shop to put a sticker over the camera, essentially blocking the camera from working. (Personally I think the latter is a much better idea, cheaper and all you have to do after POP is to tell the shop to remove the sticker and you can sell it, or even sell it to someone going to enlist.......)
As for the enlistment dates, the one on CMPB's website is only for those enlisting into Tekong. You should follow the date on your enlistment letter. Whether you are BP or not, as long as you did not get Silver and above for your NAPFA in Poly/JC/ITE, or if you never took it, you will enlist the same time as those in BP, all going in for 8 weeks of PTP.
think i misunderstood the last part but dosent those in pes bp have an extra 3-4 months before the 8 weeks of PTP? unless spf dosent have it and only applies for regular nsf? if they dont im screwed, didnt train or do anything at all for past few months just taking it easy thinking of training when i enlisted into pes bp.
, was expecting to enlist longer to get fitter before joining the regular non fit intake guys since i was also looking forward to losing the flab.
