evilerniex
MG gn-x
the part at the wrist area. looks like a bracelet :s13:
not familiar with the kit.. looking at pics, seems like part of the bracelet is hidden by the arm. can use blue-tack to stick that part? or stick to the inside of the bracelet?
theclerksays
Just finished my first airbrushed kit.. SDs are really hard..:eek:
more pics here
First airbrushed kit - SD Stargazer
how to remove nub marks properly on clear parts?:(
tarui04
think my compressor got problems
normally it auto stops at 4bar and starts at 3bar
these days I am spraying primer and when I let the compressor reach 4bar, no primer comes out until the air pressure drops to ~3.5bar then after a few strokes of spray the compressor kicks in again.
normally even under continuous spraying, the pressure will hover around 2bar with compressor running constantly.
nowadays the pressure drops very quickly after spraying just 1 piece. the pressure reading shows barely above 1bar!
I even resorted to lowering the pressure output for the airbrush and diluting the primer more but it still happens.
then i smell more thinner than there is primer coming out of the airbrush
aucheukyan
4 bar is your output pressure
:eek::eek::eek:
flanker27
ok, location marked on my phone. will go to that place to look at iwata airbrush....anyone else interested?
flanker27
Can help me check the price of the cheapest airbrush with a compressor? Thanks alot.
go iwata site and check it out? cause i will go iwata hk distro and look see if i wanna buy. that being said, compressor you wanna lug back from hk meh?
cyclonic23
Shinizan
On the talk on the Iwata airbrush. Between the Iwata Revolution and the Hobbymate airbrush which is better? They seem to be in the same price range.
tanyieern
you can always ask them for quotation
here is the site for iwata in hk Smooth Investment Co., Ltd.
Always have a quote from them before going there to purchase:D
some links here
http://forums.hardwarezone.com.sg/hobby-lovers-229/gundam-modeling-official-thread-part-4-a-3174415-52.html#post62186217
some refresh link
http://forums.hardwarezone.com.sg/61471871-post7666.html
Thanks anyway. Im not really looking for an airbrush. Just wondering the price of an airbrush after I ran out of spray paint after the first coat. Airbrush paint is much cheaper and easier to find...
tanyieern
My WIPs:D
As u can see, all is half completed. I screwed up the paint for enact, and after assembly, all the parts refused to stick together. It took me 10mins to get the enact upright... The rapheal is left on hiatus. I just ran out of paint and am hesitating to buy another can... 8.80 for a 100ml can is a ripoff. Zabanya was snapbuilt, trying to build as fast as possible. Took me 2hrs to get this far.
I have a question: when sanding nubs, i use 400, 600 and 1000 grit to sand. However, after using all three, i still have scratch marks on the parts. The colour also looks dull after sanding. Is there a way of fixing that?
thanks:D
