destin00
- Oct 7, 2011
my kit is limited...![]()
Lies, confirm got alot de.
why its always held in ulu ulu malls
Why Zanpanya shield not on the side oneS
I broke the whole backpack. I didn't really like at the side anyways. I tot of using it like bits...
its not about the quantity, its about the quality
why its always held in ulu ulu malls![]()
Still more than mine.![]()
looks good! may i ask what's the orange that you used on the raphael? any primer?
buy an action base plus wire to stick to the bits in assult mode?
Tamiya surface primer and tamiya brilliant orange
Noob question: difference between topcoat and flat coat?
Open The Toy: Gundam Expo 2012 & Stamping Campaign
They invading Nex and Coming to squeeze our money lor!!!![]()
I want to top coat my rg freedom after its finished. Top coat part by part, section by section or whole model at once? I heard that do a topcoat before putting on foil stickers. Then do another one after. Share with me how you guys do it?Topcoat can either be matte (flat), semi-gloss or gloss coats. The difference is in their finishing varying between matte and gloss. For matte, it'll usually appear duller and removes that plastic look while glossy gives a shiny, smooth reflective finish if done right.
The basics is that the topcoat layer alters the surface roughness of the kit with matte being really rough to defract more light whereas gloss is smooth, reflecting more. Colors appear to change after topcoat because of this phenomenon.
