HeeroYuy
Normally I topcoat section by section, but because I panel line and use water decals.
I topcoat the parts that needs to be panel line or decal with gloss topcoat first.
After application then I topcoat again section by section.
matt area -> flat top coat,
metallic paint -> Gloss topcoat
Gloss area -> gloss topcoat
Then I assemble after that.
tanyieern
So, build section, then do first coat of top coat. Apply panel line and decals, then do a 2nd coat before assembling. Correct? Thanks alot!
How to differentiate between matte and gloss area 0.o?
piecewise
it's how you want that part to look like. matte for a flatter look and gloss for shiny/metallic look.
and get the appropriate topcoat depending on whether you painted your kits with acrylic or lacquer paints
destin00
Build > Panel line > Decal > Topcoat. Dont spray too near though. I did it, and its horrible.
sliver0503
no waterslide for rg freedom? iirc, aikiboy recently showed is his rg freedom w decals wor..
if only waterslide can apply like tatoo.. sigh.
noForm
00qant with Stagazer Ring, too bad for revealing scrotch tapes.
tanyieern
The water slides for rg freedom i was referring to was the bandai ones. Water slide versions of the dry transfers. I know rg rx 78 has, but apparently freedom doesn't. samuel decals are limted
tanyieern
The water slides for rg freedom i was referring to was the bandai ones. Water slide versions of the dry transfers. I know rg rx 78 has, but apparently freedom doesn't. samuel decals are limited...
Isnt water slide like tatoo? Cut out decal, wet it, place the decal, take out the transparent sheet, adjust with a cotton bud. Correct?
my bad, its not transparent, its a blue sheet(thanks to sliver:D).
sliver0503
take out transparent sheet?
usually i take out e opaque blue base sheet, leave e 'transparent' sheet on e parts. before tat i gloss coat e surface. marker setter n softer i use for waterslide decal, then end off w a flat coat.
tanyieern
marker setter and softer is for? sticking and softening the decals?
Shinizan
The setter is for preparing the area you want to put the water decal, makes it easier to adjust when you slide it out. Softer is to 'melt' the decal so it can set nicely onto the part (for example into panel lines or curved surface).
Setter alone has already some 'melting' properties so some people will just use setter on flat surfaces and only use softer when its a really curve surface. Note that best to do it on gloss surface, thus topcoating gloss before application.
That's what i understand from using these 2. Got some advice on those at HAW few months back.
flanker27
guys and gals,
me gonna order stuff on hlj by latest next weekend. me order is the kotobukiya zoids panzer liger and another liger.... anyone wanna share postage, please pm me asap. i can help you ofrk half the kit price first. so the items arrive, you pay the other half plus the half of the postage.
