Spector1986
Hi guys..
This is my first attempt at painting gundam..
I think this is a pg 00.. Planning of super transarm mode!!
C & c welcome..
Spector1986
what are u trying to say
??????????????????:s11:
if u think i am comparing ur pg 00 to this "PG" 00.. then i should say u r too sensitive already.. no intentions of refering to urs unless u think ur PG 00 is as fk up as mine..
Blusttoy
Okay, so I tried TS-84 Metallic Gold on the HGUC Banshee Gundam [Unicorn Mode] to get a feel on the colour turn out as compared to the regular TS-21 Gold.
Here's the attempt at comparison picture. Since that's the only camera I have, I hope the difference can be seen at least:
- Left: TS-84 on Banshee, Right: TS-21 on Unicorn -
Both has TS-14 Black base and has not been topcoated as per Tamiya's recommendation on the can's cap. While it is clear that TS-21 is a darker, bolder gold color whereas TS-84 is lighter and mild, TS-84 has a much more smoother feel when spraying and the end result of the applied coat is also silkier and coherent as compared to TS-21 which might accumulate in blobs near the edge when spraying and has a botchiness textured look when dried.
A good representative of how TS-84 looks like in real life is:
I would say that both is not as "bling" as the other gold spraycans used by other member and won't provide a very reflective surface but if you're looking for a sophisticated and refined gold colour, TS-84 can be a worthy investment. I enjoyed using it more than other Metallic colour spraycans but of course, this is just my experience while using them and can differ per individual's preferences.
osirisx
duno is it the lighting but the pic above...kinda look like the banshee had a darker gold compared to the unicorn..
think if u want bling...can try yellow candy gloss?
alexmcqueen
yup even for airbrush mr super metallic gold is more exp than the rest and not as bling as well.
but the finish is, like wat u get from ur ts-84, smooth and fine.
Blusttoy
Hmm, thanks for the yellow candy gloss suggestion, I'll look into it.
Also, I tried taking other pictures and playing with brightness/contrast but the TS-21 always appear "gold"-er.
Maybe this will help slightly to demonstrate what I mean by darker/milder:
ultimatron
this is what i get for spraying gaia starbright gold over gloss black.
not as bling as factory chrome gold but good enough for me ;)
sliver0503
hey silver bro, may i ask how much inter frame rg freedom expose after fixed?
trying to figure if inter frame can skip the paint jobs.
For ref on inner frame structure n possible exposed frame, u can refer to here
here goes:
one side inner frame exposed
More pics for yr ref on exposed inner frame wrt completed freedom can b found
here
Bryson
Hey guys, I'm on a budget. Thinking of using ab to do paint jobs instead of buying spray cans. IMO, it cost cheaper compared to spray cans in long term right?
How much will i need to spent on a basic ab + air compressor?
Where can i buy locally? I saw on videos people have those spray booth too, is it a must?
I saw at stargek selling $200 for the basic set.
Thanks!
ongkh2000
Thanks!
u can drop them a visit to check out prices and such
Hobby Art Gallery / Hobby Art @ Work
i got mine from them. :)
aucheukyan
Hmm...do u know what PG starts for??
i know... its parental guidance, they always show it before showing the noose:s12::s12:
it's sliver not silver
wats inter frame?
inter-Milan I know
:s22::s22:
alternatively you can get from keith at airbrush.sg or taobao if you are willing to take risks, its more cheaper cause its OEM and the latter is from china=:p
AikiBoy
here goes:
here
wao thank. seem like not much are exposed.:D
Spector1986
Hi guys.. I saw those rough rough paper.. Got 200.. 400.. 600.. 800.. 1000.. 1200.. 2000.. 2400..
Wat are those for? Is it the higher number the better the grade?
