wanrong
wow, found cheapest online MG sinanju i can get is USD80 + shipping..after convert is cheaper than HAG.
But isit possible to hand paint the whole kit?(This will be the first kit that i will put some serious effort into painting it)
Cleaver
Of course it is possible to hand paint, but you will need more time than using air-brush ( ab ) or spray can....
Good luck! and dont forget to show us once its done
wanrong
Still thinking to get it :o , how much does a average paint cost? Is the some paints where i can just spray can it? Try to achieve a metalic finish on it. But rather new in this painting operation.
sliver0503
spraycans will be costly in the long run compared to ab.
i have done up a hg sinanju and a mg sazabi using spraycans, quality is not as nice as ab but if you wan spraycan metallic finish/candy gloss finish, you can refer to the following links (if you dun mind my humble work)
1) hg sinanju click here
2) mg sazabi click here
wanrong
Hi, just place an order on MG sinnaju. Was wondering if i using spraycan for metallic finish i can basically just spray all the red parts when it is in the runner?
What is the different layer of spraying?
sliver0503
Suggest u cut out e parts, trim n sand e nub then start your spraying.
Layer of spraying will b primer--> gloss black --> chrome-->clear color of your choice.
sliver0503
my humble attempt at gbwc 2012.
dun think can win anything but it was fun doing the build :)
more pics can be found here
tanyieern
Hi,
Anyone has experience with RJ London spray paints can share? How do they compare to tamiya?
Thanks in advance
wanrong
ermm...what is primer actually? :s11:
totallly nub regarding this aspect. And whats top coat and stuff? Need to solve all my enquires before my sinanju arrive. :(
sliver0503
Primer is base coat. Usually used to check for visible flaws as well as to allow subsequent co t of paint to stick better to the parts.
As for top coat. There are generally three types
Matt, semi gloss n gloss. There are used to achieve desired surface finish. U can read to here for more info.
wanrong
Ah, read that before. But thanks for the advise on premier.
still have a couple of questions tho
1. Is it cheaper to hand-paint or spray if i'm only going to paint this 1 kit?
2.If i hand paint do i still need preming?
3.To paint the emblem part do i need to Premier > gloss black > hand paint the gold part? Or i could instally hand paint it?
4.Say if i want to paint the inner frame do i still go thru the same route? Or can i just spray paint it? With say silver or gunmetal?
Thanks thanks.
sliver0503
Thanks thanks.
1. if only one kit, handpaint cheaper (do note, imho, its harder to handpaint than using the spraycan as you might get brushmarks more)
2. priming acts as a base coat for subsequent paints. i have seen cases where pple wanna paint white over red parts (without primer) and end up, the part become pink. suggest u try painting on the unwanted runners to see if you can get the results you wan first.
3. you can choose either but gloss black will be able to bring out the bling-ness of gold paint.
4. once again, i would like to mention primer acts as a base coat to allow subsequent paint to stick better.
my 4 cents
