Surge007
Thanks for the encouragement guys. Now that I tried it hopefully I can do more extensive led integrations in the future.
Wolvie: nice attempt at using gold leaf. U got the gold leaf from Artfriend? Quite expensive rite?
Cleaver
Been a while since I last pick up my paint brush, here's my latest work.
Really very nice there!
xfiles_wolvie
Me! Lol go go go wolvie! Bling bling ftw!
Wahh tuner nice macross! Long time no see!!
Good idea surge007!
thanks bro....:s12:
bought from artfriend...brand is monalisa...nt that ex....i noe more ex....u can ask the bros here. ...this is imitation gold leaf...if u wan real gold leaf, i can recommend you....:s22::s13:
Bryson
Any ab gurus here to help me?
What's the difference between 0.5mm vs 0.8mm nozzle?
I tried using 0.8mm nozzle with the 0.8mm needle but the air starts to rush back into the paint cup while the 0.5mm pre installed out from the box doesn't does this. I've tighten all screws already..
Using K-381 airbrush from Keith.
wanrong
Anyone know where to get enamel spray cans? Planning to do a reverse wash. Now left with getting enamel spray can.
The only enamel paint i can find is tamiya but this is only in bottle form.
Does RJ london carry enamel spray can as well? Other than chrome color.
Need black.
If i hand painted black will it leave alot of brush mark for enamel?
ongkh2000
Need black.
ive never heard of enamel spray cans before. if u wan enamel paint, u can try tamiya enamel and handpaint. if u using a airbrush u can ab the enamel paints.
wanrong
enamel epoxy or something? :s11: No such thing ah? sian then i'm gonna hand paint with tamiya enamel black liao.
Knightrider3K
never heard of enamel spray but gt polycarbonate spray.
cant b used for plastic model though.
http://www.tamiya.com/english/products/list/ps.htm
aucheukyan
does anything spray out?? if not is backflowing, or means that when you pull back the needle and the nozzle does not seperate to allow air to flow out and suck the paint along, but flows back into the cup.....
Installation error or faulty nozzle or needle,
P.S dont have exp with 0.8 needles, but mechanism should be the same
unicr0ne
After i tink 5-6 months no touch, so abit rusty. Here is my long long long overdue testing of the gold leafing.
Introduced by Heeroyuy bro...or ultimatron bro...old liao...forgetful...sorry.
equipment
think apply too much
after initial brush
quite bad for this one
cannot breathe too heavy and cant yawn or sneeze. the leaf flies.....easily...
more at Rx-75 Guntank Testing
your gold leafing is fugged up. Spray gold paint or use gundam marker also look 1000x better than that.
Those pieces are meant to be SMOOTH. Your gold leaf got so much flakeing going on. Redo or change method of painting gold rah!
order-devi
dumb fug, u r back to entertain us?
Spector1986
U r right!!
ultimatron
:s13:Coming from somebody who doesnt paint his kits
sliver0503
Completed this recently for a uc grpbuild for sggs
More completed pics can be found here
Those who are interested in joining the sggs's uc grpbuild can refer to here to express your interest!
hoyouken
This may be a stupid question but....
what kind of display stand you folks get for like displaying Wing zero with the angelic "overlapping leg" pose?
Seems that the action base display stand not suitable for doing this pose? Any tips and tricks to recommend?
Thanks.
