ultimatron
Hi guys... Haven't posted here in a while, happy new year! :D
Anyway, eh, I got question. Just started on my HGUC Sazabi. I'm noob at sanding (my first time). Picked up a sanding stick at HAG recently with 3 diff types of grit. But even with my finest grit, I still get scratches! I'm not sure if my technique is right - I've tried pressing the sandpaper hard, pressing it lightly, going in circles, going in one direction, etc, but the scratches are still there.
Is it bobian sand will confirm have scratch, even with the finest grit? I read that toothpaste can help polish, is it true? Or is Tamiya polishing compound my only option? Thanks gaiz :)
using 800/1000 grid sandpaper will still leave scratch marks, to get rid of those micro scratches, u need to prime and paint.
or u can using polishing compound <- correct me if im wrong, experts advice on this. thanks
ongkh2000
guys, can someone tell me if any hobby shop sell all the accessories (like color spray... gundam marker... blah blah) at WEST side? I just moved there and hardly got any chance to go down town :(
dont knwo of any hobbby shops in the west. i usually go to town
aucheukyan
yup polishing compounds, Tamiya extrafine sandpaper(1500-2000) or mws polishing films removes microsratches for opaque surfaces. Tamiya poishing compounds only for clear surfaces.....
Primer does remove microscratches, but sometimes may make some ugly splash marks on the surface....
HeeroYuy
Tempted by this side cutter.. 25 bucks..
u guys think worth it?
G-Temple Side Cutter
It's good enough~ MIJ wor~ should have some quality there. Where u buying from?.. oh just saw your img link.. Hobbymate lol
tuner
to solve my sd gundam "housing woes" after 2 yrs of long wait for ikea promotion....
I finally give in to get a new EC!
and credits to one of the bros here providing the seal proofing of the cabinet, I hope spring cleaning once every 2-3yrs!
swat444
@tuner, What did u use to seal the gaps? Any step by step instructions on how u did it? Would like to use it for mine as well :D Thanks!
Albedo
Ya, I quite enjoy these kits by kotobukiya, now building the 4th SD version. Here's those I build: SD Tuner: Patlabor
this marks 25 years of Patlabor! lets do a patlabor kit!
I got a few of the SD kits as well, but haven't got down to doing them.
noForm also fan of Patlabor?
Really nice to see that other people like Patlabor too. :D:D
tuner
just get this "Air tight tape" from Daiso, each packet 2m long, need 2 packets just to go round both sides and the top only. Its double sided tape so just peel slightly, aline, stick and go through the lengths of the cabinet that's all.
deathgazer
dude after u stick both the sides and the top, will there be enough left for the bottom of the cabinet? i also feel your idea is good for dust proof.
tuner
yes able, 2 packets are enough to go all round the cabinet. BTW, this is NOT my idea, its from another pal here in this forum sometime back which intro us to this, I'm just doing it now.
deathgazer
well thanx for sharing out also, and also thanx to the bro u mention that gave you this idea
gentoro
I saw you have some "Stack" SD Gundum in your 1st picture. Can get a close up on that and tell us whether ikea selling the glass panel or a 3rd party item? Its a good way to put in alot more figures! :) :s12:
tuner
top glass panel is smallest, one end using wire to hook up the other end held by black clips as the support. As for middle panel which is slightly bigger, use string instead as the support. Very simple idea, I'm sure some of you will come out with more presentable ideas. As for where to cut the glass panels, I got it custom cut from a glass shop. I will ask my contact for the address and price when available.
