evilerniex
Hmmm.. i'm looking for those really thin markers. As for cutters do you have any recommendations? I dont think the current i have is smooth enough to make a clean plastic cut.
This's my current one. Don't think it's good enough right?
for markers, u can get any permanent markers from stationary shops. they have very thin ones up to 0.1 and 0.05. u can try Zig or Sakura, if these brands are still around. it has been years since i used markers.
for cutters, unfortunately there arent any cheap alternatives. the more expensive ones are often better. if u are going to be in this hobby long-term, get the most expensive cutter u are comfortable in paying
Blusttoy
You can try recommended ones by evilerniex, I found some markers by Sakura at 0.1 thickness to be suitable for Gunpla panel line. Art Friend, like the one at Taka have them in stock. Copic brand is great too. Hell, just bring your Gunpla there and panel for free =:p
Got official Gundam panel markers too as discussed, should be available at HAG/Orbe/M Workshop/Other Gundam-related hobby store.
Cutter wise, yours looks okay though cutting plastic sheet is different than cutting parts from sprues.
There's cheap ones at SGD 8 which works okay and then there's those by Tamiya which may cost SGD 40+. I myself, just pre-ordered the so-called God Hand cutters, which I wonder if it will really leave the cleanest mark. My Tamiya one is starting to feel dull somehow, which I think is because I cut those thicker sprue trees.
ahkia1
I think for cutter, should really invest on a good one. once and for all :s12:
deathgazer
how much does the god hand cutter cost? see HAG/HAW got post on their fb but did not check the price with them
xKomon
I went art friend and got those sakura markers as you recommended. It's great thanks! As for the cutter i think i'll just use mine for now.
Btw where can i get the green led for the gp base? I heard its sold in a set of 8 right
000kai000
hello all the peeps here!
it's been a very long while since i last touch gunpla and i have decided to do this hobby with MG Sazabi ver ka. being release recently. Too much poison for me. :o
However, when i pick up my tools, many had been rusted and dusty
after which i decided to clean it up.
although cannot get back to it's original prime, but at least the rust is gone and it's safe too work.
Guys, which kit should i start on? :o
000kai000
my last kit was a Sinanju ver Ka. i know its not well build... there are alot of mistakes in masking the zeon gold trims
hopefully this time i can improve and be better :o
kagenoou
need advice
what colour for panel line looks good on gloss blue? currently I tried white and it is very subtle....
Also, does any1 have a scriber or buffer to recommend? I flooded some detail...
Trueblue82
yo bro just to share with you, for those gold parts, can use toothpick to paint,u can either not thin the paint or just thin it a tiny bit.:o
btw..anyone bought metal build Destiny? how much??
TangTank
Hi Guys,
There has been some crazy sales of Gunpla in the local hobby shops last year. I bought quite a number of MGs and this revived my Gunpla building hobby again!
Here is my 1st model kit of 2014!
You can visit my blog for more pictures here: www.gundam-otaku.com
xKomon
q
Guys, can i know what's the market price for this right now? Kinda interested in it. HG Build Strike Gundam Full Package Plavsky Particle Clear ver.
kaixax555
Hi, has been a while since I assembled a model kit.
Finally finished a model kit (non gunpla though, a Revell Ferrari 308 GTB) after 3 weeks of sanding, spraying, painting, gluing, decaling, topcoating etc.
Not perfect but I am happy. Learnt a lot of lessons that can be applied to Gunpla modelling, such as decalling and experimentation on which type of paints I like (found it to be lacquer, the finish is much better than acrylic)
And now... time to clear the backlog of kits from AFA 2013 (Justice is mostly done already)
Grumpyoldman
Well, dunno if I asked this before, but...
Does anyone know where can I get lobang locally for the preorder of the MG Destiny Regenes?
