TangTank
Sharing my completed MG MS-06S Zaku II v2.0 Char's Custom to form a set with my MG RX-78-2. Clean built from box, primed, airbrushed, and coated. Added some decals.
More photos HERE
000kai000
any butties can share how they sand off the nubs off the new MG hands...
the design is good, but material wise i think is similar to polycap plastic... which make it difficult to sand :(
aucheukyan
i think you can use soldering iron/ drill bits to bore holes resembling bullet marks and a regular hobby knife for the cuts on the armor pieces
do note that putting soldering iron into plastic will release toxic fumes, make sure you have sufficient ventilation before doing that.....
peekyboo
hi guys im moving from spray cans to air brushes now ... any recommend location for a good starter set or .. one of those tankless mini compressors ?
thanks in advance. do pm me if you have details where to get them !
Mikiberry
Hi I have tried asking Hobbymate and HAG but to no avail. Can anyone advise me where I can get waterslide decals for PG Strike Freedom 1/60?
Grumpyoldman
Go Facebook, look for Samueldecals
They might have. Look out for some custom sheets, they're actually better than the originals
Craze_One
Hi guys,
Kind of need some help. I have 2 friends that would be travelling overseas. One will be heading to Taiwan and another to Hong Kong. Am looking to get them to purchase me some MG kits. Which one would be cheaper to get from?
Been toying around with HG lots and thought of upgrading to MG. I kind of regretted not buying any kit from my trip to Batam. They were selling MG kits at an average of Rp.220,000 which is around SG$23.
Any information would be appreciated. Like where to get and probably how much one kit would be. Thanks in advance!
jazy1992
Hi guys,
went to HK last mth, depending on the kits u getting, can be as cheap as sgd$40 ea
jazy1992
Hi everybody, I'm new here, just wanna check if anyone know where can I get air compressor for gunpla spray painting in Singapore? Tried using the Tamiya can spray, but it's kinda expensive in the long run. Or anyone can advise which other method i can use for color painting the gundam?
u can join the most of us in the no airbrush club and use hand brush to paint, so much more cheaper.:)
