wanrong
- Oct 23, 2007
Your HD-180 no good?
somehow yesterday trying to spray it just got clotted, cant even spray thinner or anything.
Strip down and clean everything but still clotted.
Soaking the airbrush but not brusshing it works? Maybe its my needle the sharp tip have a slight bent
Any bros can recommend a good compressor with airbrush set. Wanna try airbrushing but so many models to choose from. Preferably not too high end
I also wanna know.
I see some people have a box with ventilation in which they do the airbrushing, is it necessary?
I saw the sparmax compressor that haw is doing preorders for. Just wondering if that is better or the hm5000. Also I noticed there is a lot of different kinds of airbrushes. Is a single 0.3 airbrush sufficient or need to get a few with different sizes
Is there a way to remove primer paint like how Enamel paint can be removed using Enamel thinner ?
anybody know where to get the cheapest price for rg exia ? whether online/ shops that having promo ? tia
why you want to remove primer paint ? i think the normal thinner you use to mix with paint also can remove the primer paint.
