aucheukyan
I bought mine from him last time
interchangeable(needle, nozzle, cup), but one of the 3 needles bent, get clog at times....duno where to get replacement sian:(
then bought another set from hobbykulture, also interchangeable(needle, nozzle)
has a adjustable thingy below the cup, forgot what's it for
all budget no brands model
The hobbymate 135(MWS, HAG/HAW) or the rich 35 (Hobbykulture) are both good entry airbrush and is all there is to it. Both are .3 btw
gentoro
Keith reply and he not more dealing in airbrush anymore. T_T:
bugman12
Hi to those experts here.
I started painting my kits and I realise that those tamiya/hobby spray paints are super expensive, and my first can ran out before I could finish the set of parts that I need to color.
Thus I have started sourcing out new spraypaints, like those nippon or RJ london ones.
Question is are those spray paints suitable for the plastic kits?
jazy1992
yes brands like Nippon and RJ London can be used, but do note that you will get a rougher finishing.
I've also heard from others that the pylox line of spray paints will damage the plastics though.. not sure how true is this but proceed at your own risk.
Knightrider3K
Buy off ebay lor.. Airbrush rarely spoil unless u butterfinger & drop it.
use this la. 0.5
Spray GUN Paint Tool Sprayer AIR Brush Airbrush Alloy | eBay
AikiBoy
by the way how many here collect tamashii gundam...
everytime I check some local toy shop website... always sold out fast...
jonathan464
tamashii? whats that? is it the like action figure type? i think got robot spirits (plastic) and metal build (metal parts) lines. get metal builds la. freaking awesome. can balance on 1 leg as heavy as paperweight.
besides, anyone zeng their sd neo zeong yet? i wana see pictures.
only found some pics from the kotaku website.
freakybird
Hi guys. I used to assemble a lot of model kits for ships and planes, and now I want to start some gundam kits. I moved house and now I don't have space at home to set up a place just for spray painting. Does anyone know if there are any shops that offer airbrushing service? i.e i pay they spray?
As a second question, for gundam models, do you spray paint before or after assembly/sub-assembly? I notice the parts are already separated by colour.
jazy1992
think u can use the workspace at HAG and HAW, but u have to airbrush yourself. besides, why would u wan others to do it for u? takes away the fun right?
as for your 2nd qn, its best to paint during assembly or at least after test fitting the parts. Its precisely because there's already colour separation thats why painting is optional.
