kiradex
I got some really urgent questions I'm hoping someone can advice me. I've tried painting for the first time and I'm almost done but..
1. I read that gloss coat will dull metallic paint. I'm seriously puzzled. Because right now almost my whole unicorn is in metallic paint (legs are sliver leaf and body and head while it's titanium sliver). If I give it a gloss coat before I move on to panel line and whatnot, what can I do? I really don't want the paint to dull. But it's really irritating that I can't do it now. Any advice? OR should I just go ahead?
2. Panel lining. The paint kinda went over the lines and thus, the wash won't flow smoothly (I'm speculating. It's from what I see.) Either that, or I just use the normal panel line marker and just trace is and try to lighten it to look better. My friend did advice me on using my hobby knife and try to scrape out the paint from it though.
3. I intend to do a gloss coat ( see first question) and then stickers and panel line and then finally a flat coat. I know the psychoframe can't be topcoated otherwise it will look foggy. My question is what if the topcoat seeps into the piece even after masking? Can I remove it using lacquer thinner?
Any advice anyone?
evilerniex
Any advice anyone?
1. so far I dun have any problem with gloss coat on metallic paint. if u want to play safe, u can try doing it on unwanted parts or plastic spoon.
2. gloss coat the parts so the paint flow easier. or dilute ur enamel paint more. at worst just brush through the entire line then clean up
3. how come psychoframe cant gloss coat? psychoframe is clear parts rite? can gloss, no problem.
kiradex
1. Really? I read on a few sites that people using my paint (Sliver leaf) when they go over it with the top gloss coat, the paint became not as shiny and had a dull effect. So I'm worried about that. I'll be doing it on a metal spoon tonight so yeah.
2. Yes. I intend to do that.. But, I can still see the lines. I tried to do it on another spare part I had and it totally didn't stick to it or flow well. But, when I use the gundam panel line marker, it went on just fine. The tip still could traverse the lines nicely and leave the panel lines nicely.
3. I heard that clear parts can't spray a flat coat otherwise it will fog. I'm not sure if gloss can work. I'm just wary of any type of coat for them as I do not want them to fog.. and if it fogs, how do I clear it up?
evilerniex
1. not familiar with silver leaf. I am using Gaia note paint
2. u can traverse the line with a paint brush, just need to use enamel thinner to clean off the excess
3. yup, u can clean off the paint with lacquer thinner
kiradex
1. That's the Tamiya Spray Can paint. I saw some old posts from hobbyart's blog.. someone mentioned that they use sliver leaf (it's a sliver color that's super shiny) and when they topcoated it it became dull.
2. Sometimes it doesn't stick well.. But okay. I'll see how it goes.
3. If you clean off the topcoat will it fog less? I really hope the gloss doesn't fog the psychoframe.. If it really does fog, how to fix it?
evilerniex
3. just clean off the flat coat with thinner will do.
ethan89
Hallo, are u referring to Unicorn PG?
ethan89
As much as I would like to refer to that.. I'm only doing an SD D: I'm a newbie.. so I decided to take on this kit as a trial.
Ohhhh that's cool too! I'm also quite a noob myself coz I recently started spray painting. Currently working on the PG version while waiting for my LED kit to arrive sometime this week.
Gonna be plenty of trials and errors for me since I'm looking for ways to turn it's clear psychoframe parts glittering when the LED turns on just like how it appeared in the OVA.
Good luck on your SD and hope you can share some photos of your work!!
jazy1992
dun think glittery and LEDs go hand in hand.. but who knows? maybe u can find the method to achieve it.
Jhyun
Anyone interested in the Chopper ii brought in by Hobby mate? Planning a mass order with my colleagues but we are still short of about 5 sets to hit 1 carton for the discount.
ethan89
Sending some life to this thread :D
sellingelyn
WTS
Hi all, I am looking to clear my stash of model kits i have with me. All are from bandai, and im selling at a price cheaper than your local hobby shops, you guys can compare.
MG aile strike gundam VER rm- $65 (price locally- $87-$69)
MG sinanju stein- $109 (price locally-$149-120)
MG proto wing zero- $65 (price locally-$99.50-$80)
Action base 1 Sparkle Clear Green- $13 (price locally-$15-$16)
Action Base 1 Grey- $11 (price locally- $15-$13)
Bandai Action Base 2 Sparkle Clear Red- $9 (Price locally-$12-$10)
Meet up and deal at pasir ris interchange.
ExArchz
Anyone has any extra spare parts? I need 1 shoulder attachment part from RG Exia Plate F number 7
kaixax555
Completed the Dragon Momoko Sword Strike today
Not exactly straight build, did some spraying, decaling and weathering. Didn't remove seam lines though.
Albedo
Nice.
kaixax555, can describe what u feel is different between the china version and Bandai? Will it stop u from getting from Bandai?
kaixax555
Nice work!
Thank you haha
Most of the methods are inspired by your tutorials
Nice.
For Dragon Momoko, mainly design. It really beats the Bandai version hands down. Plastic wise it is pretty decent, though to me model kits don't have particularly strong plastics anyway.
And nope, it won't stop me. My mainstay is RG kits and I would probably buy them if I really like it. For china versions, I would only buy if they are really attractive to me. This Strike caught my attention for being so good looking.
Niceee! I don't see any seam lines anyway :s13::s13::s13:
There are, maybe the camera cui haha
I learnt new methods of how to remove seam lines so I guess I should apply to my next model lol.
And I think I could be more efficient with Gunpla building. The method I use took a really long time lol.
_________________
By the way does anyone know where to get MG Strike Freedom waterslide decals locally?
I want to improve my bootleg MG Strike Freedom Gundam since I used stickers for these (and it looks ugly).
