Meteor_strike
- Apr 5, 2015
Thanks. Will head down to HAW to take a look, after MA from KKHPaints, coat etc, local hobby shops will be advisable.
The hobby shops named, HAW/HAG, they sell supplies as well.
Thanks. Will head down to HAW to take a look, after MA from KKH![]()
Just finished my RG GAT-x105 Aile Strike less the decals....
Apologies for the poor quality pic...
Nice. I got this recently too. Much better in terms of quality and overall between my 1st one, strike freedom.
Must be more adventurous mah, this hobby if dun try then cannot improve deLOL.... i have the same for RG Strike... Decided not to paint it.... I scare i will end up doing a bad job..
Sent from Samsung GT-I9505 using GAGT
think best to buy some cheap HG to try painting first. dont be like me ..
is there any work flow for painting?
eg - complete the build , then strip part by part to paint?
some online tips and tricks
quote from another thread
+paint from lighter color( yellow , white) to darker color (black, grey etc) - usually applies for HG because of masking.
MG/RG parts are mostly or all parts are already seperated nicely for you.
Do you guys wear any respirator when using Tamiya spray cans?
Any alternative type of mask that is cheaper?
result of the metallic gold (thanks all who have share tips & tricks)
1/100 MG Nu Gundam Ver.KA by Errz, on Flickr
Hand print or air brush?result of the metallic gold (thanks all who have share tips & tricks)
if i don't paint, can it do the below steps ?
gloss clear coat on bare plastic - Decal - Gloss clear coat - panel line - Flat clear coat
