evilerniex
what cleaning solution u guys use? can use the cleaning pot when changing color in between?
I use industrial thinner for general cleaning of airbrush.
I also have gaia note tools cleaning solution for soaking the parts if it gets too choked up.
cleaning pot is just a container with a filter. u still need to run thinner through ur airbrush to clean the airbrush
Bryson
What's the difference between industrial thinner and Gaia note tools cleaning solution ?
Sent from LGE LG-H815 using GAGT
kenneth0601
Probably I am kiasi, when I am switching colours, I will strip down the brush.
My cleaning solutions comprises of AAA thinner and Gaia Notes tool wash. Can grab the AAA thinner from paint shops, just buy the big tin, about $12 - $14 each. It will last you for a long time.
Errz
The industrial thinner is Lacquer base? if i use acrylic paint , is it ok to use the thinner for cleaning? any brand that i should be looking at?
are the Lacquer base thinner corrosive (not good for drain pipe)?
am getting AB real soon, so want to learn more on the cleaning, thinning of paint etc.
anyway, for the paint...
Tamiya acrylic - thin with X20A
Mr Color (Lacquer ) - thin with Mr. Leveling Thinner/ Mr. Color Thinner
correct?
evilerniex
u have to get the correct kind of thinner for ur paint.
u are referring to aqueous acrylic paint? I have not tried it, but u shld be able to use lacquer thinner for cleaning it.
so far I do not have the need to pour thinner down drain pipe. for cleaning, u usually just use a bit on toilet paper or cotton bud to clean ur airbrush. u also run thru airbrush with thinner and spray into toilet paper. so there shldnt be any thinner that u need to pour away
Errz
tamiya acrylic paint like this one
what kind of paint do u guys use?
kenneth0601
hehe, lacquer stronger smell right. will try and see.
can i use the same thinner for both brand of paint?
Yes, you can.
I am using Gaia Notes color thinner for general thinning of the paints and Mr Color's leveling thinner to serves as retarder to slow the paint from drying up.
Errz
Yes, you can.
thanks..
now waiting for my AB to reach.
dankoo
Primer
Just to check for you guys, do you use Mr Surfacer as a primer like the Mr Surfacer 1000?
