kenneth0601
Anyone knows how to minimise the nub marks on plated kit like phenex mg?
will the Gold gundam marker work?
I have a GM04 marker which I just opened, but the ink is blackish brown (not sure if its because its been in storage for too long)
Anyone bought the Dm akatsuki? not sure if I should gloss or matte it
What my friend did for his set of Phenex was hand paint the nub marks with gold paint and used some of the decals to cover them up.
tangpx
Guys, Where can i order spare parts for perfect grade gundam?
I think my pg gundam strike's hands broke. :s11::s11:
RedEyesFan
Chara Hobby revealed something amazing
HGBF SUPER FUMINA
MG WHEN?
Pierre86
Anyone know does taobao have any replacement parts for my HGUC 1/144 RX78-2 Gundam E.F.S.F Prototype Close Combat Mobile Suit Revive version as I broke the part of A1 which is the eye of the RX-78-2 while cutting it :(
tissuepaper
got pic ?
try saving using cement? cos is eye part. maybe fix back also not so obvious and not an articulation part.
tissuepaper
after applying water decal , can just seal with flat coat (my choice) ?
i have the mark setter + softer but didnt use when applying the decal.
the decal lining not so obvious anyway.
jazy1992
personally speaking i dun really use setter at all when it comes to decal, but i do use softer to melt the decals into shape as sometimes the decals will be placed over curved edges or over panel lines.
kenneth0601
If you are using 3rd party water slides, it is recommended to apply the setter on the piece before applying the decal.
Also, it depends on did you applied a first coating layer before the decal application, if you do, then setter is a must.
tissuepaper
using bandai decal.
previous experience, gloss coat it then apply softer + setter. ended pretty badly as some (bandai) decal melted.
this round didnt apply coating. soak in water then apply on top of (semi gloss) paint. decal lining not so obvious (acceptable for me). except that one small piece of decal drop off but stick back already. but not sure if should apply softer on it, only worry if it melt the whole piece :s22:
so i can apply my flat coat after this ? :s11:
kenneth0601
using bandai decal.
Apply the coat once you are done with the decals, this coat(s) will protect your decals as well.
