kenneth0601
To add on, they ship from shenzhen, which is very near the 4px warehouse. Also, 4px offers to send to popstation.
Here is one item i bought on 18th Nov, not sure why it takes so long to reach you..
I was using Skycart's services and they can only use sea shipping for the paint. Hence the longer transit.
simcher
4px lets you send paint via air?
clement.wsy
Hi Guys,
I wanted my gunpla to have the effect show in https://patrickgrade.files.wordpress.com/2012/06/11871-41.jpg"]https://patrickgrade.files.wordpress.com/2012/06/11871-41.jpg, but I don't know which kind of paint I should buy, which kind of cap should I get? If possible please show me the color chart
And what kind of coating should I use?
Thanks.
RedEyesFan
Hi Guys,
Thanks.
Matt coat?
tissuepaper
Hi Guys,
Thanks.
difficult to say which color because the modeller may have mix the color. but i think the color cloest could be mr hobby colbat blue and mr hobby/ gaia sun yellow
images
coating is up to you.
kenneth0601
Managed to shake off the laziness that crept in since the new year.
Painted the inner frame of MG Amazing Red Warrior with a little bit of copper and silver here and there.
kuatos
Hi, can any owners of PG GP01Fb help take measurements of the width and height of the scaffolding? Would like to get a GP01Fb but scared it will not fit in my cabinet.
tissuepaper
anybody follows japan gunpla modellers on instagram? wonder how they can finish a kit in 2-4 weeks time. :s22:
ddqwerty
Hi guys, looking for some advice.
Just bought my first 3 gundams, hguc 005, 109 and 191. Hyaku Shiki, gundam x and rx 78(revive) respectively.
After building, I intend to simply panel line and top coat, is it ok to panel line with the gm01/02/03 and gm301/302/303 gundam markers then spray top coat? Or top coat once then panel line then top coat again?
For the hyaku Shiki, as it is shiny, is it a must to use glossy top coat?
Thanks in advance everyone, that's all the questions I have now, might have more once I start building
evilerniex
yes, u can just panel line then topcoat.
for hyaku shiki, u dun need to topcoat the chrome parts. it may affect the shininess even if using gloss coat
ddqwerty
Thanks for the advice, learnt that nail clippers and nail files aren't good enough, gf gonna flip tables if she found out I used her stuff.
For the hyaku shiki, there's two dry transfer decals I believe, so once I manage to get them on, it's not gonna fade or come off without any coating?
One question for the pros, after cutting out a part from the runner, how long do u spend sanding a nub mark off till you're satisfied?
evilerniex
u use ur gf's nail files and nail clipper?! O_O
at least get ur own or use old unwanted ones lah
so far the dry transfer decal on my hyaku shiki still ok.. more than 5 years already.
it is not about how long u sand the nub, just sand until the nub mark is completely gone
tissuepaper
the normal nail files will be too rough. go to a hardware shop /hobby shops to get sandpaper/sanding file, 320, 600, 1000.
start from 320, then 600 and 1000 last.
and you sanded your hyaku shiki ? O_O
ddqwerty
She have a seldom used set with different cutting edges, gonna stop until I get a proper cutter, and sanding products.
Thanks for the advise, I used the manicure set which have 4 different edges, didn't seem to work very well, but maybe I'm still noob, gonna get proper ones.
I haven't build my hyaku Shiki, I like that one alot so I'll build that last, after getting more experience, hehe. I gather from your post that I cannot sand the hyaku Shiki? The gloss shine will be lost? Even if I use very high grit sand products?
