Cypher
Guys,
I m back to this hobby after a super long break.
Tried emailing samuel decals and got no response from him.
Any other sites/shops that sell customised decals? The official bandai decals does not have what i need.
Thanks.
in.darkness
God Hand Ultimate Nipper
Anyone knows where can get God Hand Ultimate Nippers 5.0for reasonable price? (<80SGD)
kaixax555
Guys,
Thanks.
Have to go Taobao search
Either Dalin or GiGi also can. They are cheap so you can buy multiple in case you screw up.
Sent from AKB48 theater using GAGT
kaixax555
Any place to recommend to get good and cheap cutters and Gundam sets?
Tools uh...
Toysinterest on carousell for cutter
Hardware store for sandpaper
Paints wise depends on what you use
BBT for Gunpla if you can wait, HAG/HAW or Orbe if you can't
discoburg
Thanks for the info.
Reserved a $16 BN Godhand GN-125 cutter from Toysinterest in Carousell.
Just bought a Astray red RG kit from BBT.
Past RG and MG kit was bought from Toymana.
Tools uh...
Blusttoy
Anyone knows where does the part G8 goes to? Can't find it.
In the crotch piece of the unit, there should be grooves that allow you to attach part G8.
This is to allow you to mount the kit on the display action base stand.
If you're not using the stand, there is no need to use part G8.
discoburg
Thanks for the explaining. Yeah i managed to attached the part G8.
I also removed that part to use on the stand with a fork like attachment.
discoburg
Just realised that the Isopropyl alcohol that I’m using from Watson is only 70%. No wonder it takes some effort to remove some paint dots when I panel mark. Any recommendation where to buy 90% IPA or other solutions to ease the removal?
RedEyesFan
Nail polish remover?
It is literally a lacquer solvent.
