kaixax555
- Nov 6, 2007
Just TS-21 Tamiya spraywah kaixax zehzeh
what did you use to paint the gold?
Sent from AKB48 theater using GAGT
Anyone have any idea if enamel spray cans are available in Sg?
Looking to do reverse wash but no airbrush
Doing Sinanju ahseems like airbrush is the way to go
anyway, can't wait for tetsujin next week![]()
Doing Sinanju ah
Unless damn good at masking or the parts are single colored.Your mr hobby white I assume is primer ?
Yes , you apply primer first , than paint than TOP coat
Paint first than build
Primer, paint, top coatNeed help guys!!! I bought a mrhobby white 1000 a few years back intending to paint my Gundam but never did it, and I forget how the step works, I put the base then paint with acrylic paint then put a top coat? And where do you guys buy the paint? And paint first or build first?
Sent from HTC U11 using GAGT
Paint first or build first up to you, personally I will do both depending on how much seamlines are in the kit
I wana do the following in the order:
1. Coat with acrylic gloss coat to cover sand marks
2. Panel line with tamiya panel line accent
3. Weathering with soft pastel..maybe wana buy tamiya weather master
4. Final coat with matte coat
U guys think its ok?
Especially step 2 using enamel paneline accent over acrylic coat
Sent from Samsung SM-G955F using GAGT
Use lacquer, in general paints with "hotter" thinners tend to be at bottom layersI wana do the following in the order:
