Nikaido
Hi everyone,
I am new to gunpla. can anyone advise if Tamiya x20 thinner can be use with Gaia note enamel paint for thinning ?
Thanks
strikefreedom_83
Been awhile since I last build. Got the itch to start building kits again after I saw the recently release gold plated Phenex Gundam.
Have not built the Narrative one but I did have a painted HGUC Phenex [from GFT] done:
Anyway, was at HAW and I picked up what I thought was the full-plated Tryon 3 kit.
I didn't do my research, so this was the campaign version and only some parts were plated, the rest were of a special pearl/gloss finish. So not my best build since I wanted to preserve the special plastic look.
I actually like the Tryon 3, even though at first I wasn't into the SRW aspect.
The backpack however blocks the shoulder articulation and the sword is heavy and the kit barely holds it in place. Fun though as a break form regular UC content.
Hi may I know how you paint your Phenex? It's really well done.
kaixax555
Hi everyone,
Thanks
Gaianotes should be lacquer wor
Need lacquer thinner
Sent from AKB48 theater using GAGT
Nikaido
oh i get acrylic base - tamiya x20A
Oil base - Tamiya x20
Lacquer based - Lacquer base thinner
Thanks it is quite confusing i thought there is only 2 type Acrylic base or Enamel oil base .
kaixax555
If really want to break down to specifics, there are 4 types
1st type is Water-based Acrylic, mainly brands like Citadel and Vallejo. Tends to suit handpainting, can also be airbrushed. You can use water to dilute or better yet, use their thinner.
2nd type is Alcohol-based Acrylic, Aqueous Hobby Color and Tamiya Acrylic belong to this category. They are better thinned with alcohol than water. They perform more like lacquer than water based acrylics. However I have good experience handpainting with Aqueous Hobby Color (see examples in works above), painting in a wet palette. Dilute with Tamiya X20A.
3rd type is Enamel. They are kind of like oil paints, and they take longer to dry and fully cure. Very smelly, wear mask when painting. Useful for panel lining and for reverse washes like you see on most people who paint their Sinanju/Sinanju Stein. In Singapore you will mainly find Tamiya Enamel (small cuboid looking bottle), though got other brands like Testors around. Dilute with Tamiya X20.
4th type is Lacquer. Very quick drying, not quite good for brush painting but excellent for airbrushing. Smelliest so you better wear a mask when painting. Dominant type of paint for most Gundam painters and modellers. Tamiya (those specifically labelled lacquer), Mr Hobby (not Aqueous Hobby), Gaianotes, E7 and SMS paints are examples. Lacquer thinners include Mr Hobby Levelling thinner, Tamiya Lacquer thinner, Gaianotes thinner, E7 thinner.
For more info can read this
http://blaze.re/paint-types/?fbclid=IwAR2t8xuJOKv0smfutuqR6FY8qCJyzfIiaHsSz1_gdZqev0w7D3BT_qLUFV8
de5ert
Any good brands of ab gun can recommend? Budget either less than 100 or 200. Is ustar kp-45 gd?
iron2000
Something interesting.
Wireless LED, the guy recreated from scratch of a 3rd party plamo product.
BtegaSG
Good info!! Thanks for sharing !!
zhihao57
Hi all, so recently I accidentally broke the joints of the shoulder,
Is there any place that sells replacement parts?
I've tried using Tamiya ABS cement, but its not strong enough.
Tried poking a needle through, but the joints are too small.
HELP!
haha!
its a MG destiny extreme burst mode.
kaixax555
HELP!
haha!
not able to put a rod inside the joint?
theclerksays
HELP!
haha!
I have a very old built MG destiny extreme burst mode that I can sell u for the parts if u want.
zhihao57
Ah, how much are you looking for?
For just a small shoulder joint? Maybe you can message me?
I've actually solved the problem alr, drilled a bigger hole, stick some round tube that I got from my HG freedom in, miraculously it fits, nicely in the arm also, woo, it's done, haha!
https://m.imgur.com/a/JXfOEXW
The left joint is the one that broken haha.
frontpage
Anyone interested in the RG perfect strike model at p-Bandai?
Looking for people to share the shipping cost
Thanks!
Nikaido
White Color on Grey Surfacer ??
Hi,
Can any pros advise if White color can be air brush on Grey Primer or strictly on white primer only as Grey is darker than White ??
unicr0ne
Hi,
can is can, but you need to paint many thin layers or one thick layer.
good luck making the parts consistent.
White is one of the most difficult colors for beginners to paint if the base is not white.
Nikaido
I see thanks i will stick to White primer then. :)
