Hard disk problem
aspeno
Just bought a Toshiba 3.5" 2Tb just hours ago to use as secondary storage. I tried to transfer a file to this new drive but the transfer speed from 15mb/s drop to 2.5Mb/s then it will hang. After a while the hard drive is not detected in my computer but is able to detect in bios. I have already change sata slots and sata cables but nothing works. Is it possible for a new hard disk to fail?:(
ZrE0_Cha0s
0_0 so fast dead?
do u have any other pc to test it???
beside that u sure its a new one?
wacko
to answer your question, it is possible for a new anything to fail.
aspeno
0_0 so fast dead?
Bought from tradepac and it was in a moisture barrier bag so it should be a new one. Got no other pc to test. I used Hd tune to scan also hang and it shows ZZZZZZ as model type.
ZrE0_Cha0s
Can try request a exchange from them??? Or send it for RMA?
*adiBOY
Within 7 days can 1 to 1 exchange no? Lemon law applies.
Buzztiger
Amazon got alot of bad review of Toshiba drives being dead on arrival. Is this why they are so cheap ?
aspeno
Crooni
sounds more like a bios/mounting problem
anyway i bought the same drive from tradepac last week
plug in 7 year old com (sb710 chipset) on port 5 with 4 other drives, ahci cannot detect, ide can detect. switched sata ports around to test, found that somehow bios can only detect hdd on sata 1 to 3 on ahci. so left it on port 5 with ahci and go windows see how.
go device manager, the drive is there.
go disk management, it's listed. so initialized using mbr (bios better not use gpt), format and mount. after backing up ~250gb of data, did a full check and scan. no errors no bad sectors.
so far so good, though reviews say will fail in 2 years after warranty ends.
anyway, before claiming the drive is broken,
1. make sure there's sufficient power (some ppl daisy chain 4 drives to 1 cable)
2. see if it's detected in bios/uefi/windows. try it as a primary drive on port1
3. check device status
4. initialize, format and mount before testing/using
