Of course lah. If your TV does not know how to decode DVB-C signals, then this box will of course have to be turned on to decode the DVB-C signals and then send them through HDMI to the TV lah.
That's what the SingTel and StarHub set top boxes are doing to send the signals to the TV too what. Via HDMI, or the lower quality Component/Composite video.
Ang Mo Kio Hub Fairprice Extra has this funke 5.1 at $59 each and every funke has an amplifier. Search Funke combo 5.1 and sure can see a pdf file about it. They can even filter out LTE signal for you. Maximum range is 40km. As long as your area is green and you put antenna near window or on window grille you should be able to receive clear image. Tv must be DVB-T2 ready. If landed house then use rooftop antenna sure can.
can I know is there a way to reassign TV channel when we received digital tv channel....seems like we have to use the remote to scroll up and down to lcate the channel.
Yes. You can also use your own RG6 Quad-Shielded Low-Loss Coaxial Cable from Belden or if you need a longer coaxial cable connected to the Funke Combo 5.1.
Not all cables are created equal. Signal loss is crucial to high-frequency signals such as those most HDTV broadcast. These cables are rated at 75 ohms and offer a larger insulating dielectric than regular coaxial cable to ensure a best possible picture every time.
Hi, bought Funke 5.1. Plugged in and scanned. No channels received. Manual scanning shows various channel Signal strength above 70% but signal quality 0%. In Punggol. 2016 Panasonic listed in mda website as certified digital TV.
Anyone facing same issue or have any advice? Thanks!
Ok guys, i been 2 months since I have the idea and finally got the time to get this done.
Did this in the DB where the the antenna input came from outside the flat and split to all the rooms. Open the box, disconnect the input cable. Then connect the digital antenna to the input port like the above photo.
Above is a closeup of the new connection.
Everything is done! At all the TVs, I still use the normal antenna cables from the wall to the TV. Just go into settings to switch to Digital signal and rescan for the HD digital channels. I am able to get digital HD signal in all the TVs in all the rooms. All my TVs have digital tuner built in. But I suppose it will work with set-top boxes.
With this setup I'm able to get 100% on Quality and between 60%-70% on signal strength. Guess is due to the placement of the antenna. But even with these figures, no problem watching all the channels. Will continue monitoring and update if there's problem.
I see there are 2 benefits with this setup:
1) No need to buy extra antennas for each TV, thus cost savings
2) Aesthetically pleasing, since no need to put any external antenna in each room near windows or TV
And lastly guess which digital antenna did I use?
A cheap pigtail one free from a friend
Just want to share my experience. Any thoughts? Happy tweaking!
I am considering the same path, and im thinking of diy the antenna and wire it up to the enclosure to make it one hugeass antenna. Thanks for proving this could work.
