Help! ASUS N65U settings
ngbc
I am also having the same no Internet Access from Asus N65U but my MIO TV and MIO Voice are working.
I used Singtel-MIO profile and my connection is:
ONT--->ASUS-----(3)-->2Wire (for MIO Voice)
. . . . . . . . . |-----(4)-->MIO Settop box
. . . . . . . . . |-----(1)-->PC (No internet access)
. . . . . . . . . +----(2)-->PC (No internet access)
Any help is welcome. Thank you.
Are you able to ping ip address like 8.8.8.8 ?
You may want to try playing around with the hardware acceleration (HWA) and port forwarding (PP):
eg,
1.Enable both HWA & PP
2.Disabe both HWA & PP
3.Enable HWA, Disable PP
4.Disable HWA, Enable PP
Remember to reboot router after every change.
Last resort, set manually :
Good luck!
Hoam Chu
Hi NGBC
Thank you for the help. I tried all your settings but it did not work at all. The router is connected to Internet but the PC cannot connect to Internet at all.
ngbc
Hoam Chu
Contacted Asus Support and was asked to call Avertek. Was advised to do a hard reset. However, after the hard reset, it became even worst. It cycled between "Check Connection" and "Internet Setup" and keep asking to unplug modem power cable and plug in modem power cable. So, it could be a faulty set. Will call Avertek again to arrange for exchange.
Problem resolved after topping up to change to N66U, lost the USB3 that attracts me to buy N65U.
Thanks NGBC for the help rendered.
jereme310790
Just RMAed my N65U, top up $50 for a N66U :s13: Everything working fine now. Very satisfied with the performance!
Windowlover
Can enlighten me about wireless speed improvement and any disconnect as I'm using A5520N PACE encountered disconnect sometime of the days...
