Help! ASUS N65U settings
jereme310790
Hi, I am currently trying to replace my black 2Wire modem with the N65U. After connecting the N65U to the ONT, I could not get the QIS (Quick internet setup) to work. Can someone post the configuration of their QIS for me to follow?
PS: I am on 100mbps Singtel fiber plan with DV and Mio tv. TIA :D
jereme310790
I followed everythere alr. My physical connections are correct, just that the QIS cannot detect my network at all.
ngbc
Only port #1 of the ONT is active. Make sure you didn't connect to any other ports by mistake and remember to set the ISP profile to Singtel-MIO and reboot both ONT & N65U.
jereme310790
http://i47.tinypic.com/2chxthk.png
Yes, i only connected it to port 1 of the ONT, rebooted both the devices alr. I started the ONT first den the N65U, I don't know how to carry on from now onwards.
ngbc
OK, I recalled that M1 users using the M1-Fiber preset on firmware v3.0.0.x.x encounter sort of 'bug' and need to :
1.) Enable Port-forwarding.
2.) Disable Hardware Accelerator
before internet is working. You may want to try these setting to see if that worked for you !
jereme310790
Hi, I tried both methods but it doesn't work :s11: I've tried disabling hardware acceleration and enabling port forward on ASUS RT-N65U firmware version 3.0.0.4.342. And btw is the MAC address important also? I don't know what to set, I just clicked on the 'MAC clone' button and proceeded.
ngbc
Weird leh, you already set the Singtei-MIO preset right?
Probably a lemon set, RMA it then !
maylyn
Are you able to manual setup your Internet settings?
Under WAN
Basic Config
WAN Connection Type ~ Automatic IP
Enable WAN ~ Yes
Enable NAT ~ Yes
Enable UPnP ~ Yes
WAN DNS Settings
Connect to DNS server automatically ~ Yes
Under LAN > IPTV
Port
Select ISP Profile ~ SingTel MIO (LAN port 3 ~> 2Wire WAN port for DV, LAN port 4 ~> MIO STB)
fribro
For me first I set ont-->pace router-->Asus router-->pc.
Get the Asus router for Internet connection first than.
Next go to lan and manual.config iptv first line vid 10 and 0 priority. Reboot and plug out your pace router and keep now plug in your Asus router should have Internet liao.
I using old router Asus n16 no mio tv and voice.
jereme310790
Any difference if I connect it your way? I am currently ONT->ASUS->2WIRE->PC. Will give this method a try to see if it can work.
jereme310790
Under WAN
Basic Config
Enable WAN ~ Yes
Enable NAT ~ Yes
Enable UPnP ~ Yes
WAN DNS Settings
Under LAN > IPTV
Port
These settings that you mentioned are the default settings when i booted up the router. I didn't change any of it. :/
ngbc
Already set to mio preset, this set just came back from RMA. Previous owner RMAed it. lol
Oh, you got it from pmmo99? Hmm, can't think of any other suggestion, wait for maylyn's further comments -- he is related to Asus if i'm not wrong...
ngbc
Yeap, its from him. thanks for the help. I don't know if i should RMA it. :/
You're welcome...
BTW, just google and found 2 other N65U users having internet problem connecting it to Singtel Fiber - both can obtain WAN ip but unable to surf ....no further update from them.
http://forums.hardwarezone.com.sg/n...asus-rt-n65u-issue-singtel-fiber-4058583.html
http://forums.hardwarezone.com.sg/n...m-320/asus-rt-n65u-singtel-fiber-3956436.html
May be you can try PM them :)
jereme310790
Updates: I am still unable to detect any WAN connections when plugged into the ONT. I am currently in taiwan until end of march. If there are no solutions then I'll just RMA it when I come back. Thanks for the help guys.
Hoam Chu
I am also having the same no Internet Access from Asus N65U but my MIO TV and MIO Voice are working.
I used Singtel-MIO profile and my connection is:
ONT--->ASUS-----(3)-->2Wire (for MIO Voice)
. . . . . . . . . |-----(4)-->MIO Settop box
. . . . . . . . . |-----(1)-->PC (No internet access)
. . . . . . . . . +----(2)-->PC (No internet access)
Any help is welcome. Thank you.
