[HELP] Blue Screen
Koenig168
voltech
Try with 1 stick of RAM first and see if it occurs. And if you have multiple RAMs, test them out one by one. Alternatively, you can run the memtest86.
ZrE0_Cha0s
seems like ram issues though, either ram spoil or the mobo ram slot spoil.
but another possibilities is the boot disk that have some space allocated for page file.
voltech
x1aojie
ZrE0_Cha0s
How to I check if is mobo ram slot spoil?
Sent from Samsung SM-N910G using GAGT
u can only get 1 ram to test each slots with the memtest they do to check if ram issues, but if ram have issues the test won't pass, but if ram slots issues will have a pass but the ram slots spoil is only when u using a certain parts of the ram and it will have blurscreen.
x1aojie
well the test we ask u to do best in bios or another interface (can't rmb what it call), but will get a full ram checks so the ram isn't been use so they will be able to read all empty ram.
I have installed the program, and also format the USB drive. but nth happen when i click finish.
ZrE0_Cha0s
well if u can, select either f2 or del access to your bios, change your start up/boot drive to your usb drive. save and restart and it can work.
x1aojie
Any problem?
ZrE0_Cha0s
wow that's a lot of red bar/highligh u have :s22:
yup like what he say time to send for repairs :D
oh ya, is your ram stick 16GB or u nv remove and test it? (although u can try eraser method to clean the gold contact and test 1 stick at a time to see if all happens to have or only 1. so that u dun need to bring down everything, unless its really everything =:p)
x1aojie
I have 4 ram. 4gb/ram. So how should I test it? Which test should I select? I dont have to retest everything right? Where do I get the report? I leave it afk and it retest 2nd time. But I could find the report
