[HELP!] Building new cpu
ash like snow
Hi! I'm considering to build a new cpu as my current one is almost 6yrs and yesterday just experienced bsod for once~ I know nothing about hardware so would appreciate if u guys could help me =:p
Budget: $1.6-$1.8k (monitor not included)
Usage: csgo, dota2, netflix
Preferred: rbg parts related
Below is my current cpu' spec, bought it around $1.2k. Any parts worth/able to salvage? :s13:
Mclairs83
i'm still on my 4th generation i7 rig.
think it can last another 1 more yr.
Mclairs83
erm why not? base on ur current gaming pattern. still can last longer than that.
NightRaven49
U mean mine still can last at least 1 year?
Sent from Home using GAGT
if take care, can last long long. his pc and ur pc so different also cannot liddat compare. bsod if doesnt recur frequently then nothing to worry about, maybe just suay that one time.
anyway realistically if wanna upgrade, the only thing u can salvage are ur storage (ssd and hdd), case and probably ur psu but not very likely since 6yrs old already unless ur psu got like 10 yr warranty. everything else cannot be used on modern systems, so either throw or sell on carou. but there really isnt a need to, if system is stable and meets ur requirements there isnt a good reason to upgrade.
