[HELP] Extreme Gaming Rig PC
ValechoR
I have never built a pc before(really know nuts). Hoping to get some advise over here. So after doing some research, I came up with this build (I need advice on whether can it be better? Thanks Thanks.
Mobo - ASUS ROG ZENITH EXTREME x399
Cpu - AMD Ryzen Threadripper 1950X
Gpu - ASUS ROG-STRIX-GTX1080TI-O11G-GAMING GeForce 11GB
Ram - G.SKILL TridentZ RGB Series 32GB (4 x 8GB) 288-Pin DDR4 3000MHz
SSD - Samsung 960 EVO Series - 1TB PCIe NVMe - M.2 Internal SSD
HDD - WD Blue 1TB SATA 6 Gb/s 7200 RPM 64MB Cache 3.5
PSU - EVGA SuperNOVA 1000 P2 80+ PLATINUM, 1000W
Cooling - NZXT Kraken X62 All-in-One 280mm CPU Liquid Cooling System
Case - Corsair Crystal Series 570X RGB
strahl
I have never built a pc in my life and i’m sick and tired of paying for shitty computers that don’t last/perform. BUT I NEED YOUR HELP GUYS. So after doing some preliminary research, I came up with a build (I need advice on whether it would work well or can it be better? Thanks Thanks.
Mobo - MSI X370 XPOWER GAMING TITANIUM
Hi.
You should be going for a corresponding x399 (not x370) board for ur 1950x.
Other than that just make sure ur case supports the dimensions of your eATX/ATX board.
Stock availability might be an issue for your parts also. Do check.
Also, re-evaluate if u really need to drop a bomb for that 1950x.
An 8700k will more than suffice for gaming and daily usage.
Crimson_FURY
This PC for gaming only? If so dont bother with threadripper. Get the intel 8700K. For gaming 16GB also more than enough ram
ValechoR
Thanks for replies strahl and Crimson_FURY bros , so basically i shld just get 8700k and
z370 mobo will do ? (ASUS ROG Maximus X Hero Z370)
strahl
Yes Sir.
An 8700k w/x370 would be more than enough imho. For the board just go with 1)reliability and 2)features that u will actually use aka Usb ports / RGB etc. U should read up on it.
2x8 GB of ram is enough and would leave u with future upgradability if u need it in the future.
Just to emphasize, re-evaluate on ur usage. Really. Unless u have cash to splash.lol.
ValechoR
Thanks bro, currently ive revamp into this setup. Just wanna squeeze as much fps i can get. Will 2x1080ti help? Cos i heard is just sharing the load. Sry, i know not much about parts, just hearsay.
I currently have a 1080gfx with i7-6700k 32gb ram com now, built by aftershock. But its not as promising as it looks. Fps is really lacking. Its not as smooth as i wanted it to be. Sigh...
Mobo - ASUS ROG Maximus X Hero (Wi-Fi AC)
Cpu - i7-8700k
LED Accessories - NZXT AER 140 RGB Starter Kit with 2 Fan
LED Strips - NZXT HUE+ Extension Kit (AC-HPL03-10)
ZrE0_Cha0s
Hmm...TS should really look into the issues and not building a new PC, since a i7 6700k with GTX 1080 is still a very good PC for current gaming,
Maybe U can tell us what games u were playig at what kind of settings. Next is that which monitor u were using? Moreover how much FPS are u getting for playing at that setting and resolution?
Building another PC compared to your current one, I would said that u only gain a few FPS. But u still burn quite a lot of money (unless that is your least of your concerns.) :o
ValechoR
I'm playing pubg. my fps is at 70-90 at very low settings, sometimes drop to 50-60. I have already send it back to aftershock but came back same (facepalm)
Im using Benq 2546 dyac 240hz monitor. Its pretty bad i feel, constant jerking.
raysusan
pubg engine is very bad in optimizing ...
btw 6700k with 1080 is really still a beast now
-Synchronicity-
This is quite normal for pubg. Your parts are fine.
ValechoR
Yeah, thats what the staffs from aftershock says but, my fren built the exactly same com but his fps is constant 100+. (facepalm)
Irenicus
Hi ValechoR,
Your i7-6700K and GTX1080 is still a very capable gaming rig.
Have you checked whether all the drivers installed are the latest? Also check whether your video card and other components are seated properly.
Did your friend overclock his rig or run at stock speed? Maybe his fps are higher due to overclocking.
Also check your CPU and GPU temperature. If it is too high, it might lead to thermal throttling and fps drop.
dreamyxq
Lol i7 + 1080 + 32gb ram still not enough still wan upgrade, sibei elite sia..
Born with platinum spoon in mouth ah?
SpInErGy
Asus Rampage VI Extreme barely clear 570X...
So any board smaller than R6E will be good for 570X
AC2
I can also say my fps constant 200+ lol. Ppl say u believed so easily. Go his house and take a look or ask him use his handphone take video of the fps. There are always ppl that like to bluff , 50 can say 500 , 100 can say 1000
Byfrost
Can be better. Swap the GTX1080Ti out to Titan Xp (second gen). The GTX1080Ti chip is slightly crippled chip with less CUDA Cores than the Titan Xp (3584 Cores For 1080Ti vs 3840 Cores for Titan Xp), buy 2 to SLI the Titan Xp.
Probably can change processor to Intel i9 7980XE (18C 36T) instead of Threadripper 1950X (16C 32T) which means Motherboard need to change also.
