[HELP!!!!] MOI IS BALDING!!!
see_what_see
bros!!! I realised moi hair is thinning recently. I have been busy the past months and didn't really pay much attention but now that I am less focused on my commitments, I realised its getting worst :(
I'm not sure if this is caused by hormones but I have to say my complexion was bad the the past few months and also been having stubborn pimples on my scalp.
Each time I shampoo my hair, I see about 20+ strands on my palms :(
Anybuttie has some good advice for moi:s11:
cet87
wet your hair and comb it downwards..
hub8246
I heard someone said using ginger helps. Not too sure. Google ginger and hair regrowth got some results. You can go do some research. Not sure if it works for you or not.
revil78
Soon your teeth will drop, your muscle weakened, bone lost, eyesight and hearing worsen.
live with it, this is life
CAShop
Instead of asking a certified trichologist, TS brings problem into EDMW to get trolled. Definitely will solve your problem
wlalala
Go and see a doctor
You might be having some skin disease
xbidamanx
I realized I was a balding buibui one day when I needed more facial foam than shampoo during my shower...
