HELP Needed, CPU Red Led Keeps Blinking
tigerwoods
From your video, it didn't pass the CPU check. Take out the motherboard + RAM + CPU + GPU and bring them to Performance PC Pte Ltd or Nigel at SLS. They can swap RAM, GPU and CPU with their working PSU. If the cpu is bad, you can get a used CPU for about $120. I got mine i5 9400 from Carousell for $110.
Do you know how much Performance PC Pte Ltd or Nigel charge for their service?
86technie
1) Try out the CMOS battery
This will reset the CMOS than try again.
2) Put one stick of RAM at one time.
This issue can be either BIOS or RAM issue.
Try reset the CMOS first see how.
Once the PC booted, update the BIOS
https://www.msi.com/Motherboard/B360-GAMING-PRO-CARBON/support
If unsure bring to a shop let them check or bing to Corbell let them check
for you since the RAM is under them.
Corbell might need recepit/invoice for RMA.
tigerwoods
Already tried 1 & 2
RAM sticks is working fine tested on another PC
Seems like the MB or CPU cant detect the RAM sticks
