helpaboyineed
- Sep 14, 2016
As the rma for EVGA is quite good (base on one of the hwz user over here.) and if u have any issues, email to EVGA and see if they can transfer ur card to their taiwan side, so u can just send it over to EVGA taiwan and wait for it to come back. (at least your waiting time wont be longer than u send to usa.)
if u have the budget get FTW or SC (cant rmb which is better.)
Hi, was just looking at my current PSU's specs, and realised it only has one 6 pin connector and a 6+2pin connector, while the GTX 1070 FTW requires 2 8-pin connectors, that means I cant get the GTX 1070 FTW or I need to change a PSU ah?
buy 3 fan need around how much? my casing specs says only can fit 3 fans including the default one eh
